Author: Subject: Urgent issue
S1502
posted on 12/8/16 at 11:31 AM Reply With Quote
Urgent issue
Big problems with my car. Running a silvertop zetec on efi injection with a Mondeo Ecu.
Car is idling a little rough but my issue is when you put it in gear in solutters and jumps like a kagaroo then stalls.
I have changed the leads, plugs, coil pack and cleaned the throttle body and maf. Still nothing.
I have disconnected and reconnected the ecu and battery. Tried the engine without the maf, throttle and lambda sensors but still no joy.
Anyone have any suggestions as im missing out in all the good weaher and just want to drive.
posted on 12/8/16 at 11:49 AM Reply With Quote
Not sure how you'd check, but is there enough fuel pressure?
JimSpencer
posted on 12/8/16 at 11:54 AM Reply With Quote
Are you sure the clutch is disengaging properly?
S1502
posted on 12/8/16 at 12:08 PM Reply With Quote
Yes i beleive so if it wasnt then surely it would stall at idle?
40inches
posted on 12/8/16 at 12:10 PM Reply With Quote
Try starting it in gear, brake on.
S1502
posted on 12/8/16 at 12:41 PM Reply With Quote
Will try that tomorrow. What will that prove? Im starting to think it may be fuel pressure under load
40inches
posted on 12/8/16 at 12:52 PM Reply With Quote
If the clutch is disengaging or not. Car jerks forward and stalls= clutch engaged. Engine starts = clutch disengaged
mcg
posted on 12/8/16 at 01:32 PM Reply With Quote
Old fuel? Blocked fuel pump / filter?
I had both of these issues recently that caused my redtop to chug under power. Was fine on idle.
S1502
posted on 12/8/16 at 01:48 PM Reply With Quote
Cant be old fuel new ish tank. Will have to check pump and filter but never done this before.
Matth93
posted on 12/8/16 at 04:53 PM Reply With Quote
Make sure you've got no air leaks/split hoses on the inlet manifold that could cause rough running
S1502
posted on 12/8/16 at 05:54 PM Reply With Quote
Have done the inlet manifold already and thats fine. Its as soon as it goes into a gear and you get moving the whole engine gets spluttery and jumpy and cuts
big_wasa
posted on 12/8/16 at 06:17 PM Reply With Quote
Still sounds like an air leak or the ecu is missing a signal.
What age is the ecu ? As obd2 would stop you guessing.
S1502
posted on 12/8/16 at 11:42 PM Reply With Quote
Old ecu about 1995. Will disconnect and reconnect it up tomorrow i have a spare so will try that aswell
Hornet
posted on 13/8/16 at 09:48 AM Reply With Quote
Can you give a little more info. Does it stall without being in gear when you press the acc pedal?
posted on 13/8/16 at 10:33 AM Reply With Quote
Has the car ever run properly? Is it a new installation?
S1502
posted on 13/8/16 at 01:27 PM Reply With Quote
No so it starts and runs in neutral. If you rev it in neutral then no issue either. If you put in gear and drive off it splutters, jumps and cuts. The car was running fine then suddenly this no previous issues
ianm67
posted on 13/8/16 at 01:36 PM Reply With Quote
Sounds like a fuelling issue to me....... Blocked fuel filter or the tank not venting properly perhaps?
Always biting off more than I can chew.....
