New Topic New Reply
Author: Subject: Electrolysis problems
VinceGledhill
posted on 17/8/16 at 07:23 PM Reply With Quote
Some years ago I read the Electrolysis see the light thread, and filed it, deep in my brain for later retrieval.
Well now's the time and I have stripped my MGF ready for the Ariel atom style build, but I've failed.
I put about half a bag of soda crystals into water and gave it a stir. I then got out my trusty battery charger, connected the negative to the "part" and the positive to one of the old bolts from the donor.
This picture was after a week, still rusty. Where did I go wrong?
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
posted on 17/8/16 at 07:29 PM Reply With Quote
Add some salt to the solution and start with nice clean mild-steel anode.
Sheet steel works best as anode Surface area facing the cathode should be as large as possible.
[Edited on 17/8/16 by britishtrident]
[I] What use our work, Bennet, if we cannot care for those we love? .
theconrodkid
posted on 17/8/16 at 07:31 PM Reply With Quote
afaik rust will only be removed from the part of the part being de-rusted that can "see" the other anode ?.
you need a much bigger item connected to the +....i hope that makes sense
who cares who wins
pass the pork pies
View User's Profile E-Mail User View All Posts By User U2U Member   theconrodkid 's Aim   theconrodkid 's Yahoo
Bigheppy
posted on 17/8/16 at 07:46 PM Reply With Quote
Make sure the croc clip has clean metal to connect to
r1_pete
posted on 17/8/16 at 07:52 PM Reply With Quote
As Conrod & BT say it works very close to line of sight, if you line the container with a sheet steel anode you'll get results.
joneh
posted on 17/8/16 at 07:54 PM Reply With Quote
Make sure the Croc clips bite into clean metal. I bashed some old box section flat and wired them together to form a circle to surround my parts. Make sure they're as close to your part as possible without touching.
Try using a smaller container, like a bucket. You should see bubbles within a couple of minutes.
gremlin1234
posted on 17/8/16 at 08:20 PM Reply With Quote
are you using the right soda crystals?
there are three types with very similar names, would have to check which is which though.
baking soda
washing soda
or
caustic soda
posted on 18/8/16 at 08:15 AM Reply With Quote
Actually thinking about it for that syle of part I would probably just pickle it in vinegar for a couple of weeks. Then immediately wash off in baking soda buffer solution.
Irony
posted on 18/8/16 at 08:27 AM Reply With Quote
I used a bit of old metal bar from concrete reinforcing. I bent it in a spring shape and placed the part inside the coil. Making sure they don't touch of course. You should see bubbles with a couple of minutes.
My charger has a 'normal' charge setting and a 'charge/start'. You can definitely see a huge difference between the settings. Many more bubbles on the higher setting.
posted on 18/8/16 at 08:30 AM Reply With Quote
A single bolt simply isn't big enough for the anode, you need something with far more surface area e.g. a sheet of steel or multiple steel rods.
Irony
posted on 18/8/16 at 09:57 AM Reply With Quote
Oh and don't use a played or stainless anode. It releases significantly nasty chemicals.
posted on 18/8/16 at 02:20 PM Reply With Quote
So, a big piece of steel down one side of the box. drill a hole in it and BOLT the cable on...
Grip with the part with a pair of mole grips again drill a hole in the handle and BOLT the wire on.
What sort of ampage is your battery charger? Is it one of them 'smart' jobbies?
Ideally you need a power supply with a good 5~6 amps out.
I use a laptop charger, gives out 17v and 6amps. Does the job...
Before..
24 hours later...
loggyboy
posted on 18/8/16 at 02:34 PM Reply With Quote
An old brake disc is a great anode - cheap (ie free), easy to get, nice large surface area & flat ish.
[Edited on 18-8-16 by loggyboy]
posted on 18/8/16 at 03:13 PM Reply With Quote
Yep, last time I used two brake disc, one each side of the tank and it worked a treat, if a bit messy! They dont half degrade quick!!
loggyboy
posted on 18/8/16 at 03:35 PM Reply With Quote
Thats the best sign its working well !
Mark100
posted on 23/8/16 at 07:50 PM Reply With Quote
im in leeds two I have spare grahite anoids (much cleaner ) you can have if you like I put one on each side of tank. I have a thread on here somewere for details
New Topic New Reply
