Author: Subject: cable ties
steveabr
posted on 24/8/16 at 06:38 AM Reply With Quote
cable ties
Hi guys
Finally managed to beat the electrics, and all wiring is sleeved in split tubing. I was just wondering is it acceptable to cable tie rear cables to the frame of the car. Or should I bracket it to free.
russbost
posted on 24/8/16 at 07:15 AM Reply With Quote
Providing there is nothing going to chaff then fine to cable tie. We usually make 10mm long rubber "stand offs" made from petrol hose or similar, looks neater & keeps everything with a bit of "wiggle room".
adithorp
posted on 24/8/16 at 07:49 AM Reply With Quote
Also worth noting IVA don't like the stick on cable tie bases and remember to keep the spacing below 300mm
[Edited on 24/8/16 by adithorp]
http://jpsc.org.uk/forum/
Toprivetguns
posted on 24/8/16 at 09:44 AM Reply With Quote
Morning,
I used these.
http://www.cotel.co.uk/p/619/screw-in-cable-tie-mount
Need, strong and tidy.
Only drive as fast as your angel can fly... !
steveabr
posted on 24/8/16 at 02:56 PM Reply With Quote
Cheers for advice guys, next job when I return from hols
