Author: Subject: fuel pump running continuously - when hot weather?
AlexXtreme
posted on 24/8/16 at 03:59 PM Reply With Quote
Driving home from work yesterday in +25C and stuck in a traffic jam on the m'way when suddenly I could hear what sounded the fuel pump running continuously... re-started engine with no difference.
The sound stopped after a 4 or 5 mins and then restarted after a minute for around 15mins overall until I got going again and then the pump seemed to go back to normal. Any idea what is happening to do this? It did not sounds like the pump was running dry and I had 80% full tank.
Alex
johnemms
posted on 24/8/16 at 04:38 PM Reply With Quote
Tin Top?
Sounds like the lift pump in the tank is on the way out..
Fiddley but usually easy to change..
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
posted on 24/8/16 at 05:13 PM Reply With Quote
Cyrstal ball required ---- car engine and fueling type and type of pump ?
[Edited on 24/8/16 by britishtrident]
AlexXtreme
posted on 24/8/16 at 05:31 PM Reply With Quote
Sorry Ginetta g27 running twin 40 carbs with a silver top
Pump right under the tank which looks like a Facit type and quite new
posted on 24/8/16 at 05:43 PM Reply With Quote
Silver top fuel pressure is away too high it should be below 2.5 psi
AlexXtreme
posted on 24/8/16 at 06:09 PM Reply With Quote
Zetec silver top Engine - Pump is not easy to look at atm
arrow-engineering
posted on 24/8/16 at 07:08 PM Reply With Quote
sure it wasnt the rad fan?
AlexXtreme
posted on 24/8/16 at 09:35 PM Reply With Quote
Definitely not the rad fan.. that was running as well :-) and I have a light that shows when this is on... the noise was from behind me and turned off when the engine was turned off something that the rad fan would not do!
Alex
AlexXtreme
posted on 25/8/16 at 06:54 AM Reply With Quote
Also does not sound like it is running dry...
chris
posted on 25/8/16 at 12:22 PM Reply With Quote
nowt to worry about mine does the same in hot weather
AlexXtreme
posted on 25/8/16 at 12:28 PM Reply With Quote
Thanks Chris.. :-) could it be the fuel vaporising in the heat somewhere (pipes / carbs?)?
I guess the pumps are designed to last for years as long as their is petrol going through them to keep act as cooling.
Alex
Ugg10
posted on 25/8/16 at 12:43 PM Reply With Quote
Daft suggestion, what ecu, is the fuel pump relay picking up the rad fan signal somewhere along the line?
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
AlexXtreme
posted on 25/8/16 at 12:50 PM Reply With Quote
do not think so.. the fan comes on most times I stop the car and have not heard the pump come on then...
