Author: Subject: 4-1 Exhaust collector
ttalps2000
posted on 30/8/16 at 03:17 PM Reply With Quote
Does anyone have a good solution for stopping a 4-1 exhaust manifold collector from vibrating and making a horrible noise when being revved? I have tried the trick of using cheap silicon to seal it up, which worked for a bit, but has started doing it again now!
Next step is to weld the thing up completely?
Matt
posted on 30/8/16 at 03:23 PM Reply With Quote
Crush gaskets?
ttalps2000
posted on 30/8/16 at 03:40 PM Reply With Quote
how do they work?
posted on 30/8/16 at 03:47 PM Reply With Quote
Err, they are like folder metal that you bolt up and they crush down to size.. Can help with a bit of movement..
ttalps2000
posted on 30/8/16 at 03:49 PM Reply With Quote
but the pipes go inside each other, so wouldn't work!
loggyboy
posted on 30/8/16 at 03:58 PM Reply With Quote
try heatproof/intumescent sealant.
[Edited on 30-8-16 by loggyboy]
Mistral Motorsport
snapper
posted on 30/8/16 at 05:44 PM Reply With Quote
I cut the outer pipe in 2 places and used a large Miklor clamp
You can use the white exhaust sealer as that expands with use
I eat to survive
I drink to forget
Shooter63
posted on 30/8/16 at 07:52 PM Reply With Quote
When I start building my exhaust, I plan to use a spring and tags to hold the pipes in the collector, it normally works OK.
Shooter
ianhurley20
posted on 30/8/16 at 08:30 PM Reply With Quote
Weld it - I did mine, much better :-)
SPYDER
posted on 30/8/16 at 08:35 PM Reply With Quote
Hi Matt! What is holding it together at the moment? Springs? Tabs?
I only have two fairly strong springs on mine. It doesn't rattle at all.
coyoteboy
posted on 30/8/16 at 08:39 PM Reply With Quote
Weld it.
ttalps2000
posted on 31/8/16 at 11:12 AM Reply With Quote
at the moment it has 2 tags with a split pin though the middle. The pipes do not try and separate, but they resonate like mad!
Might try some of that fire place type sealant. The normal exhaust type paste goes off hard and then cracks and falls out from my experience.
I don't have enough room to get individual clamps around the pipes
posted on 31/8/16 at 01:51 PM Reply With Quote
Fireplace cement goes hard and falls out as well. Revving the log burner up to 300°c doesn't help...
ttalps2000
posted on 31/8/16 at 02:20 PM Reply With Quote
I think im just going to end up welding it together and being done with it, got to be the best way!
