Author: Subject: Stuck for ideas to progress with my project
locoboy
posted on 31/8/16 at 09:18 PM Reply With Quote
I've got a deep down fascination with mechanical things (as most of you probably have too) and I also really like over engineered things, you know, chairs made of threaded water pipe , engine block coffee tables, lamps made from bicycle components and other simple every day items that are made from industrial parts!
Maybe I'm alone in this or maybe I'm not......
Anyway I have a piece of railway 'equipment ' that I have acquired and I really fancy making an industrial looking bottle opener!
It's the sort of item that would look great in a big swanky garden where there is a dedicated bbq area and would make a great conversation piece come party time!
My sister (the one with the brains in the family) has the house and dedicated bbq area and I reckon this would be a pretty cool addition to her outdoor entertaining area.
I'd could be fixed to the side of her out door covered deck area or affixed to a stand alone timber post - anyway what to fit it to is not the issue.
I can create linear movement with it but every bottle opener I have researched relies on a rotational movement to essentially ' peel' the top off.
Does anyone have any ideas (sketches welcome!) Of how I could remove a bottle top with a linear movement?
I have a vision of some kind of locater point/stop that comes from the mounting surface that the bottle cap is placed up against then move the lever and the top is removed.
See my video to get an idea of what I'm working with
[youtube]https://youtu.be/MXlnG3AcTT8[/youtube]
I'm ready to crack on and get some bits custom made if needs be, get it all blasted and painted/lacquered but I'm stuffed if I can't figure this bit out!
Col
P.'s can't get the bleeding YouTube link to work!
[Edited on 31/8/16 by locoboy]
Locoboy
posted on 31/8/16 at 10:44 PM Reply With Quote
locoboy
posted on 1/9/16 at 06:15 AM Reply With Quote
Cheers!
Locoboy
gremlin1234
posted on 1/9/16 at 08:29 AM Reply With Quote
you can open a bottle on the edge of a wall, by holding the cap on the edge, and pushing the other side of the cap down.
so maybe a small edge on the backplate, and align the 'press' to push the cap down.
