Author: Subject: 2ltr zetec turbo engine
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 10/9/16 at 01:42 PM Reply With Quote
As above wanted please pm me
posted on 10/9/16 at 04:17 PM Reply With Quote
What spec??
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 10/9/16 at 04:27 PM Reply With Quote
Pm,d
Originally posted by coozer
What spec??
jossey
posted on 11/9/16 at 07:09 AM Reply With Quote
I have one but it's mega high spec.
Engine is a Ford Mondeo zetec E bottom end fitted with forged pistons, HD bearings, new HP oil pump, new water pump. The head is a new (not recon) Focus blacktop fitted with Piper performance valve springs.
Raceline sump
The induction is a custom made system based on a Jenvey inlet manifold, large plenum with large throttle body. 625cc Siemans Daka injectors.
Bailey dump valve.
Custom charge cooler with own separate water system, radiators mounted in front of engine radiator, separate water pump (Focus RS) and header tank.
Turbo is a Subaru Impreza TD04L on a Focus exhaust manifold, custom exhaust system, currently running 18PSI of boost.
Engine management is MS2, with boost control, MSD coilpack and leads. Launch control via dash mounted switch.
Built by Bailey.
Running 270 at the mo on 16psi
Will do 20
David Johnson
