Author: Subject: Cheap/free silver top Zetec parts - King's Lynn
frodo_monkey
posted on 12/9/16 at 04:52 PM Reply With Quote
Hi everybody,
I'm in the middle of replacing the silvertop 2000cc Zetec in my Fiesta race car after it span 2x big end bearings (oil leak) so I have the remains of the old engine (and some other bits I had in the garage) up for grabs:
Zetec 2.0l bare block - £20
Crank (will definitely need looking at due to bearing issue!) - free
4x pistons (as above, x2 should be good) - free
Standard sump (looks to have had a repair at some point, maybe good to modify?) - free
Oil pickup and splash plate - free
Standard cam cover - £10, pic below
Red painted cam cover - £20, pic below
2x s/h (but working) Escort/Fiesta style waterpumps - £5 each
Inlet/fuel rail/throttle body assembly - £20, pic below
Plus a load of other odds and sods - if you need a random little bolt or whatever, ask or it goes in the bin
Will do the lot for £50, but you'll have to come and get it! I'm near King's Lynn, postcode PE32 1HH. Could maybe post smaller bits, prices above plus P&P. Either u2u me or email si (underscore) frowen (at) yahoo.co.uk
Si
[Edited on 12/9/16 by frodo_monkey]
"Racing is life. Anything before or after is just waiting."
Alexd186
posted on 12/9/16 at 06:55 PM Reply With Quote
Pretty sure my mate was after some grey / beige injectors from a 2 litre silver top, how much posted if you have these?
frodo_monkey
posted on 12/9/16 at 07:25 PM Reply With Quote
You can see the injectors in the bottom picture - kind of a brown colour. These came with my replacement engine (I'm on carbs) so I can't guarantee they are good, but everything else on the engine had been rebuilt/replaced so they're probably OK. How about £10 plus p&p?
Regards,
Si
Myke 2463
posted on 13/9/16 at 09:50 AM Reply With Quote
you have u2u ref block.
Be Lucky Mike.
frodo_monkey
posted on 13/9/16 at 11:36 AM Reply With Quote
All u2u's replied to.
frodo_monkey
posted on 14/9/16 at 08:15 PM Reply With Quote
Block now sold.
frodo_monkey
posted on 18/9/16 at 10:30 AM Reply With Quote
Fuel rail/injectors now sold.
Had a root through the garage - now also have the following:
- 2.0l silvertop cylinder head (standard)
- 2.0l silvertop cams (standard)
The cams are currently out of the head - after £25 for the head, £25 for both cams or £40 for the lot. Will throw in some followers and pulley wheels etc if you want them.
FatChapChipChop
posted on 18/9/16 at 05:25 PM Reply With Quote
U2U re: red cam cover ..
Drive fast, don't look back!
frodo_monkey
posted on 18/9/16 at 06:58 PM Reply With Quote
Seen and replied
frodo_monkey
posted on 2/10/16 at 03:34 PM Reply With Quote
So had another clean out! In total I have the following left, all from silvertop Zetec unless stated otherwise:
- cam cover - painted burgundy and fitted with a different breather. £20
- standard cam cover. £10
- black plastic cam cover - don't know where this came from! Blacktop maybe? £5
- Ford alternator. Untested by me, no reason to suspect it's duff. £10
- Zetec 1.8 flywheel. £10
- Zetec 2.0 cams and pulleys. £25
- sump, baffle plate and oil pickup. Sump looks to have been repaired (see the 'gack' on the LH side). £free
- Ford inlet manifold and throttle body. £10
- Fiesta XR2i instruments. £10
- crankcase breather, 13mm fitting. £2
- AN8 Jaz fuel tip over valve - as new in packaging, £20 from Rally Design, £5 to you
Collection on anything from PE32 1HH near King's Lynn, although I'm driving to the Lakes next Fri and back Sun so could maybe drop off enroute. May post smaller stuff at buyers expense.
Si
