Author: Subject: Importance of using the correct oil.
posted on 14/9/16 at 12:03 PM Reply With Quote
If you are sceptical for the need for using synthetic oils in modern engines watch this short Youtube video
GM Vauxhal-Opel & Saab engines are known to have problems if mineral oils are used.
posted on 14/9/16 at 12:27 PM Reply With Quote
Always follow the manufacturers advice - they're pretty clear on oil specs and when to change.
theconrodkid
posted on 14/9/16 at 01:52 PM Reply With Quote
I remember when the MK 3 escort came out,my co used petrol ones and they knew better than Ford when it came to oil.
a lot seized,when the sumps were removed there was litrally just enough room to swing a crank and the sludge was inches thick....this was after only about a year of use.
who cares who wins
pass the pork pies
ian locostzx9rc2
posted on 14/9/16 at 02:53 PM Reply With Quote
So how many miles age of the vehicle what oil was used and did it have regular oil change intervals ? Give us a clue...
40inches
posted on 14/9/16 at 03:23 PM Reply With Quote
Looks like a SAAB? Many SAAB engines replaced under warranty, because they specified a semi-synth with a 10,000 MILE change.
The CAT is directly under the sump, with very little clearance. Wonder what the sump looks like in that video?
Toprivetguns
posted on 14/9/16 at 05:15 PM Reply With Quote
Doesn't he state 196,000 miles on the video? Looks like long intervals between oil services IMHO.
My signum 2.0T is always changed between 5000-6000 miles. Horror stories of clogged oil scavenge pipes due to the poor clearance between sump and mesh are quite common.
Only drive as fast as your angel can fly... !
Slimy38
posted on 14/9/16 at 08:03 PM Reply With Quote
Oddly enough, I am tempted by a SAAB and have been looking into oil issues. Seeing one 'in the flesh' really shows how bad it can get.
Problem is in my price range I'm looking at home serviced SAAB's, and without removing the top of the engine I'm going to have trouble checking the state of the engine.
Wadders
posted on 15/9/16 at 07:28 AM Reply With Quote
Only time I would disagree is "long life" service intervals. For example If I took VW's advice the oil changes on my Transporter would be done every 20,000 miles or so.
Personally regard this as asking for trouble, so do an oil and filter change in between services.
v8kid
posted on 15/9/16 at 12:20 PM Reply With Quote
I puzzled about this on my traffic until I went to do the oil change (spec is every 18.000 miles) - it took nearly 2 gallons! Easy way to extend service life is to double the oil capacity.
Having said that like Wadders I change oil & filter every 10,000 miles its a cheap insurance - now at 180K and going strong.
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
posted on 15/9/16 at 12:22 PM Reply With Quote
GM ran into major sludge problems with these engines at the start of the 2,000's in the space of a couple of years they upgraded the specified oil first to semi-synthetic then fully synthetic.
As mentioned earlier in the thread it was considered to caused by to the oil getting toasted by heat exhaust catalyst.
Synthetic oils will tolerate much higher temperatures without braking down and forming gunge, they have solvent and detergent properties that prevent and disolve varnishes that form on internal parts.
v8kid
posted on 15/9/16 at 12:50 PM Reply With Quote
Very interesting intuitively I assumed that sludge was caused by cool running ( i.e. no thermostat) hence the water condensation was not evaporating off. So it is caused by overtemp breaking the oil down into some other compound?
Cheers!
posted on 15/9/16 at 01:46 PM Reply With Quote
Cheers!
likewise I work on 10k miles between oil changes.
40inches
posted on 15/9/16 at 03:13 PM Reply With Quote
Look at the photo, 3rd row down Sump Sludge
mcerd1
posted on 15/9/16 at 03:42 PM Reply With Quote
for comparison here's my donor engine as it came out:
Donor Pinto
Donor Pinto
don't have any pics of the sump, but there was only a little sludge stuck to the bottom / in the corners
thats after 151,000 miles at 17 years old (the last few sitting in a field not moving) and thats with maybe 1 oil change a year if they remembered with whatever cheap oil they had from the tractors on the farm (any random grade that looked about right)
johnemms
posted on 15/9/16 at 05:08 PM Reply With Quote
My old Toyota Estima had the EGR routed to the top of the cam cover.
Exhaust soot was built up inside - I cleaned it and removed all the EGR.
I know the re circulation of exhaust keeps temps lower..
But the soot getting into the oil was terrible..
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
