Author: Subject: Open diff, drum brakes etc... change?
russtik
posted on 18/9/16 at 09:00 PM Reply With Quote
So I've got a 7" Sierra open diff (clean but noisy), push-in drive shafts (perfect condition) and drum brakes (great condition). I'd like an LSD. Options:
- Sierra viscous LSD, change out to unequal length lobro drive shafts and hubs and swap to disc brakes.
- Keep current shafts, drum brakes & fit a Quaife ATB.
Thought, opinions, difference in cost?
SouthernKitCars.com
'Like' SKCC on Facebook - https://www.facebook.com/Southernkitcars
nobrakes
posted on 20/9/16 at 12:35 PM Reply With Quote
The handbrake on Sierra rear discs is well known for not being very good.
How does the cost of a Quaife compare to a second hand Sierra LSD and rebuild? (I'm assuming that it'll quite likely need a rebuild to restore the limited slip)
chris
posted on 20/9/16 at 02:12 PM Reply With Quote
The handbrake on my old drum open diff setup was ok now lsd with discs handbrake fantastick
HowardB
posted on 20/9/16 at 02:29 PM Reply With Quote
The LSD vd non-LSD is well discussed. Often an old LSD will be set for the original and much heavier car.
My Fury doesn't have a standard double wishbone at the rear, instead having a strut and an odd shapped carrier.
I do know that repair kits for the old style UJ are difficult to get hold of, so if there is a need to upgrade then ensuring the correct UJ is a good plan. I did toy with the idea of changing to an MX5 diff, shafts and rear discs,. gave up as I concentrated on getting the front end sorted 1st.
Adi is extremely knowledgeable,...
Howard
scimjim
posted on 4/10/16 at 09:52 AM Reply With Quote
There is a third (most locost) option - modify shafts to bolted flange, keep drums and fit Ford 7" LSD?
