Author: Subject: C20XE Cam Cover Breather Modification
mcg
posted on 22/9/16 at 01:31 PM Reply With Quote
Has anyone here done it and has any pictures i can look at? I have this from SBD that i plan to use:
http://www.sbdev.co.uk/Info_sheets/Oil_systems/VX%202L%20SBD%20Cam%20cover%20breathing%20modification.pdf
Any tips would be greatly appreciated!
Many thanks
Matt
skippad
posted on 22/9/16 at 03:34 PM Reply With Quote
i did this mod many years ago... it does work, blank off one of the small pipes and the other one to a catch tank.
As it says make sure to clean all sealant off, cut plate to size and refit
mcg
posted on 22/9/16 at 06:49 PM Reply With Quote
Great. Thanks for the reply. I am not familiar with a catch tank.
Is it literally somewhere for the excess oil to sit, that is manually emptied, or does it have a way of re entering the system?
Scottish Westy
posted on 23/11/16 at 10:38 PM Reply With Quote
A tank that catches any excess oil that leaves the rocker cover. If its fills you empty it manually, it doesnt return to the engine.
HTH
