Banana
posted on 26/9/16 at 05:46 PM |
Wrong kind of black
Can someone recommend a black paint that will closest match the colour of a standard MK wishbone?
I had my lowers all shot blasted and tested some black metal semi gloss from Aldi on them - but the finish is almost too glossy.
I guess they are powder coated originally from MK and this gives a much more subtle gloss finish..
any ideas?
Just let them get dirty perhaps..
Nickp
posted on 26/9/16 at 06:31 PM |
Toolstation do a matt/satin/gloss versions of black, seems decent stuff, just used gloss on my 'bones
myke pocock
posted on 26/9/16 at 06:47 PM |
Christ!!! at my age I would love to give my bones a quick coat of paint to freshen them up. Sadly I will be changing my name to Arthur Itus!
gremlin1234
posted on 26/9/16 at 07:25 PM |
any ideas?
give the paint a rub of 240grit 'sandpaper' should dull it down quite well
ReMan
posted on 26/9/16 at 08:27 PM |
Satin is closer to the powdercoat gloss imho
www.plusnine.co.uk
posted on 26/9/16 at 08:49 PM |
Plasticote rattle can satin black is very close imho
Banana
posted on 26/9/16 at 09:11 PM |
Well I was going to try Plasticote, however i called them to make an enquiry and they advised against it for this type of application.
I might key it with some 240 paper, then apply some rattle can satin black. Should be pretty well protected by the end of it!
PAUL FISHER
posted on 26/9/16 at 09:59 PM |
I used Wilko's satin black spray paint on my Mk, it was a perfect match to the Mk powder coat.
Banana
posted on 27/9/16 at 07:08 AM |
Thanks, i'll give that a go.
