Author: Subject: m. o. t. query
nick-york
posted on 26/9/16 at 09:33 PM Reply With Quote
m. o. t. query
Hi! I took my van in for its mot today. I told the bloke there that I'd put a new tyre on the spare wheel and that it was in the back of the van because I couldn't fit it under the van in its normal place. he said he wouldn't even look at the spare wheel because it wasn't part of the mot test! now I've always thought that it was checked and that it had the legal requirement of tread on it. I'm sure it used to get checked. so have they changed the mots or have spare wheels never been checked please?
adithorp
posted on 26/9/16 at 09:49 PM Reply With Quote
Spare tyre isn't part of the test. Never has been.
http://jpsc.org.uk/forum/
Slimy38
posted on 26/9/16 at 09:54 PM Reply With Quote
So the view that illegal spare tyres should be taken out before an mot is just an urban myth?
I have to admit, it's something my dad told me, and I've always assumed it to be true!
theduck
posted on 26/9/16 at 10:29 PM Reply With Quote
I was also under the impression the spare had to be legal if present.
adithorp
Yes.
...and the rear wiper/washer and reverse lights don't matter either.
CosKev3
posted on 26/9/16 at 10:45 PM Reply With Quote
Does seem stupid it doesn't get tested if fitted,as if you need to use it and it's bald what's the point of carrying it!
MOT manual states:
Tyres fitted to the road wheels only. The vehicle presenter should be informed when it is noticed that there is a defective tyre on a spare wheel.
gremlin1234
posted on 26/9/16 at 11:32 PM Reply With Quote
no they do not need to be checked
This inspection applies to tyres fitted to the road wheels only. The vehicle presenter should be informed when it is noticed that there is a defective tyre on a spare wheel.
edit 'ditto'!
[Edited on 26/9/16 by gremlin1234]
907
posted on 27/9/16 at 06:58 AM Reply With Quote
I have a spare wheel on the back of the Seven, but the tyres are directional.
Must remember to only get punctures in the near side wheels.
Paul G
posted on 27/9/16 at 07:15 AM Reply With Quote
Carrying an illegal spare is an offence ,possibly under the construction and use regs , intent to use etc but as others have pointed out it is not a testable item . Another thing that isn't tested is the speedo operation
posted on 27/9/16 at 10:20 AM Reply With Quote
My understanding is also that the spare wheel/tyre doesn't get inspected. To me it seems daft as what would you do with the spare in the event of a puncture...fit it to the car.
Mr Whippy
posted on 27/9/16 at 11:09 AM Reply With Quote
what happens if you get a puncture? surely at that point the spare (or old wheel) is less than legal
there is no requirement to carry a spare at all and certainly no rules as to what you can carry in the boot of your car....drugs or dead bodies excluded
benchmark51
posted on 27/9/16 at 01:19 PM Reply With Quote
Paul G
That's why I only bought 4 new tyres, they are directional. I have a good tyre as a spare that isn't
directional so can go either side and get me home. I have now got a puncture outfit and mini compressor,
I have used them before and they do the job. Just in case of double puncture
loggyboy
posted on 27/9/16 at 01:41 PM Reply With Quote
Spare tyre is not mentioned C&U except for regs relating to the use of temporary tyres (such as speed and weight of vehicle).
Speedo has been tested in MoT since 2012.
[Edited on 27-9-16 by loggyboy]
Mistral Motorsport
SteveWalker
posted on 27/9/16 at 02:25 PM Reply With Quote
I suppose the problem is that there is no requirement for a spare, so it would be rather harsh to fail an MOT just because there was a wheel in the back that you might never intend as a spare.
benchmark51
posted on 27/9/16 at 02:53 PM Reply With Quote
I seem to remember years ago 60's - 70's, if you were nicked for a defective tyre you could also be done for an illegal spare. So if you had 4 baldies on the car and another in the boot you would get an endorsement for each tyre and the fine.
posted on 27/9/16 at 05:17 PM Reply With Quote
The speedo isn't tested it only has to be present with a largely unbroken screen . It is not tested to check it's working !
If stopped by the boys in blue , if they check the condition of the spare which is subsequently found to be illegal you can be prosecuted
for intent to use. If the spare is flat you cannot be done! I don't know which regulations apply which is why is wrote possibly Cand U.
gremlin1234
posted on 27/9/16 at 05:42 PM Reply With Quote
it would fail if its clearly inoperative, and its backlight has to work
ianhurley20
posted on 27/9/16 at 09:49 PM Reply With Quote
Where on earth did that come from! You really must be having a giraffe.
That never happened.
Balldies on the ground yes but why would something you are not obliged to carry and was in your boot carry any penalty!
Forget it - didn't happen.
loggyboy
posted on 27/9/16 at 11:30 PM Reply With Quote
Can some people not read manuals? or do they just assume that their mate knows everything or that because they were told it once it must be true?
If someone ever corrects me i make sure i check before spouting further misleading rubbish.
From the MOT manual
Reason for Rejection
1. Speedometer not fitted.
2. Speedometer incomplete, clearly inoperative or the dial glass broken or missing.
3. The speedometer cannot be illuminated.
And there is no such thing as a law for intending to use an illegal spare tyre. That is just blatantly wrong.
Heres a list of offences... none mention a spare or intent to use.
https://www.gov.uk/penalty-points-endorsements/endorsement-codes-and-penalty-points
Mistral Motorsport
