Author: Subject: ZX12R Engine Identification
Jeano
posted on 1/10/16 at 01:40 PM Reply With Quote
Morning All,
Is there any way to identify the engine model/year of the engine in the car?
I was looking at getting a GiPro for the car so needed it for that however also just wanted to know for the future.
Drives: Robin Hood 2B
CosKev3
posted on 1/10/16 at 01:46 PM Reply With Quote
Pretty sure the engine mountings are different on the head,and throttle bodies are different.
Has yours got throttle bodies with a single butterfly?
Jeano
posted on 1/10/16 at 01:54 PM Reply With Quote
Im pritty sure i have a single butterfly but not sure, anything else i can check or measure when i have a look at the car next?
twybrow
posted on 1/10/16 at 02:25 PM Reply With Quote
As above, the obvious difference is on the engine mounting on the zorst side. The ecu connectors also changed between the A and B models. You can also use the engine number - there was a recent post about Kawasaki engine numbers.
Jeano
posted on 2/10/16 at 03:54 PM Reply With Quote
I found the mounts and they seems to be roughly in line with the 2 outer exhaust ports as shown below
Also i can confirm the throttle body is singular
i couldnt locate the code?
Jeano
posted on 2/10/16 at 04:02 PM Reply With Quote
I have also located the ECU and found the code ZX12 1200 (21175-1065, 112100-0470)
twybrow
posted on 2/10/16 at 07:19 PM Reply With Quote
Pretty sure you have an A1 or A2 from that. The engine code is on the top of the gearbox on the horizontal surface.
Jeano
posted on 3/10/16 at 10:07 AM Reply With Quote
Or thanks for this, i saw an earlier post in regards to the ZX12R having restrictions in the early gears.
did you buy a GI pro atre?
or are they worth buying?
Jeano
posted on 24/10/16 at 06:09 PM Reply With Quote
For reference the guys confirmed from my ECU code that my engine is A1 a 2000 model
