Author: Subject: Giant Autumn Bargain Clearout Part 2
jambojeef
posted on 3/10/16 at 04:09 PM Reply With Quote
Hi All - see below for Thatcham Cat 1 alarm, various engine parts, lights etc etc
Lights £8
Pedals £4
Fuel Pump from Caterham 1.6 £5
Focus ST170 Pedal box with clutch master cylinder £10
20t Mild Steel trigger wheel - centre bore approx 40mm, OD 65mm - good for speedo trigger £5
1.8 CVH Engine - condition unknown! everything you can see in the pic - fuel pump, carb, water rail, head + block etc £50
Cone breather / carb filter - 60mm inlet I think, 80mm total height £3
Brake fluid reservoir (ex BMW e39) - 3 outlets with float switch for low brake fluid warning £8
Twin H4 Hi-Lo 4500k HID kit - was on my VFR and very very bright - 1 new bulb needed £15
MGF Heater Box with fan, wiring and matrix - could be modified to suit a 7 if you're keen! £10
Sierra Bolt-On Shaft rear wheel bearing kit - think one side only £5
Cortina Solid Discs - Suit westfield and so on - New - surface rust from storage £8 pair
New TOAD Ai 606 Thatcham Cat 1 Alarm and Immobiliser with 2 fobs and instruction - fitted briefly to check operation - £45
jambojeef
posted on 3/10/16 at 04:17 PM Reply With Quote
Stainless braided brake hoses M10 x 1 - 380mm overall - ask me to check if interested £15 pair
Lower part of ST170 steering column £10
2002 ST170 Front Uprights £15 pair
2002 ST170 Battery Box and Strap £5
Sierra 1.8CVH Alternator £15
Zetec 1.8 Flywheel £30
Sierra Pressure Plate £10
Sierra Sandwich plate CVH £15
I believe these are referred to as "Dinky Winkaz" £5
Ford Oil Cooler Sandwich plate - bolt between oil filter and block and T the tails into the cooling system for instant oil cooling £15
Leather Gear Surround Mk2 MGF £5
Pair MGF Electric Mirrors - suit westfield with the right loom £15
jambojeef
posted on 3/10/16 at 04:19 PM Reply With Quote
MGF 1.8 VVC Flywheel and pressure plate £15
MGF header tank and cap £8
MGF Airbox and filter £10
MGF Wiper mechanism and motor £10
jambojeef
posted on 3/10/16 at 06:50 PM Reply With Quote
Ive also forgotten to list a starter motor and one or two other bits you can see in the pictures! U2U if you see anything you need
posted on 3/10/16 at 09:46 PM Reply With Quote
Have you got the drive shafts off the ST??
jambojeef
posted on 3/10/16 at 10:12 PM Reply With Quote
Hi Steve,
No fraid not
jambojeef
posted on 4/10/16 at 06:44 PM Reply With Quote
Thatcham Alarm sold pending payment
maurof74
posted on 26/6/17 at 09:49 PM Reply With Quote
Are the heater and wiper mechanism still available ?
Thanks,
Mauro
femster87
posted on 27/6/17 at 07:36 AM Reply With Quote
Can I have the Dinky waz
GavMax
posted on 27/6/17 at 11:43 AM Reply With Quote
Second dibs on the wiper please
ianm67
posted on 27/6/17 at 02:00 PM Reply With Quote
The original post is 8 months old...........
Always biting off more than I can chew.....
jambojeef
posted on 27/6/17 at 05:56 PM Reply With Quote
although the dinky winkaz are still available!
u2u me
jambojeef
posted on 28/6/17 at 12:25 PM Reply With Quote
Holy thread resurrection batman!
Wiper mechanism - sold
Dinky winkaz - sold
Fuel pump - sold
Brake lines - sold
Thanks to all - there are actually still lots of bits left if anyone else wants to turn back the hands of time?
ChrisLeary
posted on 28/6/17 at 12:51 PM Reply With Quote
Are the brake hoses still available?
Chris
Don't force it! Get a bigger hammer...
jambojeef
posted on 28/6/17 at 12:54 PM Reply With Quote
Hi Chris,
As per previous post sold Im afraid - cheers for your interest though
donn006
posted on 29/6/17 at 04:49 PM Reply With Quote
Still looking for pics of the be dion
