Author: Subject: Suggest a header tank?
Joshy
posted on 9/10/16 at 08:16 AM Reply With Quote
Hi all,
I'm running a 2.0L Zetec silvertop in my Haynes Roadster, and require a header tank with a single 15/16mm diameter feed nozzle, and a steam vent. Can anyone suggest something suitable?
Josh
Ugg10
posted on 9/10/16 at 08:26 AM Reply With Quote
I used a Volvo 740/760 one on my fury, comes with a nice bracket that could be bolted to the bulkhead.
Volvo 740 Header Tank/Coolant Reservoir 1276040
Available new
Genuine Volvo 740 All, 960 1991, Expansion Tank
Make up an ally bracket to go round the middle.
[Edited on 9/10/16 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
big_wasa
posted on 9/10/16 at 09:07 AM Reply With Quote
My current one is a Volvo C70. My last one was an Mgtf.
Both fine.
rdodger
posted on 9/10/16 at 10:13 AM Reply With Quote
Freelander is neat and cheap. I used one on my build. It must be good as Caterham use them!
Land Rover Freelander 1 (96-06) Header Coolant Expansion Tank & Cap - Bearmach
Joshy
posted on 7/12/16 at 09:56 PM Reply With Quote
Ended up buying a Renault Clio MK2 header tank. Designed and 3D printed a bracket to mount it to the bulkhead, and cover the steering column in the process.
Josh
posted on 8/12/16 at 10:31 AM Reply With Quote
From memory I used one from a VW Polo. At the time I had a local scrapyard that would let you roam around and remove things. Not sure scrappys like that exist anymore.
