Author: Subject: which bike carbs?
scotty g
posted on 9/10/16 at 12:55 PM Reply With Quote
which bike carbs?
Hi all, I'm currently running a 1.8 silvertop Zetec through a downdraft Weber twin choke carb and a X-Flow manifold with the spark coming from a standard Ford CVH Edis module system. It all works pretty well but im chasing a bit more power so I have a pair of zetec 2.0 cams on order and plan on going bike carbs so my question is what size carbs would you lovely people recommend, 600cc, 750cc or 1000cc?
Also any suggestions on what brand?
Cheers guys. Scott.
posted on 9/10/16 at 01:32 PM Reply With Quote
ZX9R 40mm.
I had them on my 1.8 with 2.0 cams and after a tune at Bogg Brothers all was well including decent mpg..
scotty g
posted on 9/10/16 at 01:58 PM Reply With Quote
Very nice. Did you just send off the whole thing and how much did they charge you matey?
posted on 9/10/16 at 02:04 PM Reply With Quote
You need to take the car as they use the rolling road to set them up.
It was a long time ago and if I remember rightly it was 80 for the setup.
BaileyPerformance
posted on 9/10/16 at 04:14 PM Reply With Quote
Your using an EDIS module on its own? If EDIS and not ESC your timing with be fixed at 19deg.
This needs ti be sorted before you change carbs :-) you'll gain loads of power!
GRBBONGO
posted on 9/10/16 at 08:34 PM Reply With Quote
I run zx9r carbs on my 1.8 blacktop and runs sweet.
SJ
posted on 10/10/16 at 08:10 AM Reply With Quote
ZX6 carbs work really well on a Zetec. I've got them on my 2.0. On a modified engine the bigger ZX9 carbs might give some more power but on a standard car they will be pretty much the same. The ZX6 carbs have the advantage of an adjustable needle, which I think the ZX9s don't have.
I run mine with a Megajolt & Ford EDIS.
Stu
scotty g
posted on 10/10/16 at 12:04 PM Reply With Quote
Pretty sure it's the ESC one matey.
BaileyPerformance
posted on 10/10/16 at 02:56 PM Reply With Quote
is it red with a vac connection?
BaileyPerformance
posted on 10/10/16 at 02:58 PM Reply With Quote
ZX9 or R1 carbs work great.
block air corrector, dont just drill out mains :-)
scotty g
posted on 10/10/16 at 03:22 PM Reply With Quote
Na it's all black but does have the vac tube connection.
