Zetecsierra
posted on 9/10/16 at 08:39 PM |
My diff is 83bs 4003 ba.. I/2 anyone got info on this 1.8 pinto sierra ex metropolitan police cid car
AdrianH
posted on 9/10/16 at 09:09 PM |
http://www.super7thheaven.co.uk/components/sierra_rear_differential/
Have a look on the link above it may help.
Adrian
Why do I have to make the tools to finish the job? More time then money.
mcerd1
posted on 10/10/16 at 07:55 AM |
The trouble with the part numbers is that they are on little metal tags that are easily swapped or get so badly corroded that you can't read
them properly.....
the link above gives you the info you'll need to work out what you've got, but if your still not sure then post a few pics and count the
teeth / number of turns of the input for 1 turn of the outputs.
for a 1.8 pinto my money would be on a 7" open diff with push-in shafts and a 3.92 ratio, but I can't be sure about that as there are
quite a few options and you never know if its had the diff swapped at some point....
