New Topic New Reply
Author: Subject: Seamless tube for wishbones
craigdiver
posted on 11/10/16 at 07:38 PM Reply With Quote
Hi, having a bit of difficulty sourcing some 19mm & 25mm seamless tube for wishbones.
I have found a pipe supplier that does it but are asking questions such as wall thickness etc.
Does anyone in the know, know the spec of the tube needed? (The supplier says 19mm not common O/D, it would be something like 20.4mm?).
OR where to get it in Scotland?
Craig
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
craigdiver
posted on 11/10/16 at 08:08 PM Reply With Quote
Found an answer on the interweb from Talon Motorsport;
lower wishbone tubing is 25x2mm or 1"x14gauge CDS upper tube I use 19x2mm or 3/4x14gauge CDS both are mechanical grade Cold drawn seamless.
Is this purchased from a steel or pipe supplier?
daviep
posted on 11/10/16 at 08:35 PM Reply With Quote
I got mine from Hydraulic Power Services in Leven, it was 10+ years ago so no idea on grade actual grade, it was definitely CDS though.
Davie
hearbear
posted on 11/10/16 at 10:03 PM Reply With Quote
What about Alexander's in Stirling and Edinburgh Linky to site
3.9Ltr SSC Stylus should be fun
ste
posted on 11/10/16 at 10:09 PM Reply With Quote
http://www.steelexpress.co.uk/structuralsteel/seamless-tubes.html
mark chandler
posted on 12/10/16 at 06:01 AM Reply With Quote
Lower wishbones, I used second hand Land Rover panhard rods, costs pennies as people through them away when the ball joints fail.
hicost blade
posted on 12/10/16 at 08:23 AM Reply With Quote
Seamless tube specifiaction:
CFS3 - Cold drawn mechanical tube
Can be bought from:
http://www.steeltubedirect.co.uk/
(Hub le Bas retail site...)
Dave
procomp
posted on 12/10/16 at 01:03 PM Reply With Quote
Hi
Don't use 3mm wall tube, you'll bend the chassis before the wishbone in an accident. 2mm / 14guage is most commonly used.
Cheers Matt
craigdiver
posted on 12/10/16 at 09:14 PM Reply With Quote
Thank you all
New Topic New Reply
