Fandango
posted on 12/10/16 at 01:18 PM |
Poly Bushes
Hi all
I need a set of poly bushes, (8 in total, for upper and lower wishbones, both sides) for the front of the Locost.
The ones listed online do not seem to state dimensions, so is there a generic Locost size for these, and does anyone here sell them?
As a guide I have measured;
Centre shaft length 39.40, Inside Dia 12.38, Outside Dia 19.22
2 x poly bushes per shaft Ouside dia 28.60 Length 16.80, Outside dia of shoulder 34.46
Bolt outside diameter 11.85
Cheers Carl
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me." Hunter S Thompson
steve m
posted on 12/10/16 at 05:41 PM |
Ive changed my locost suspension to poly bushes, and had to grind about 2mm of each side of the whishbone eye to allow for the poly bush shoulder to
fit
also the crush tubes with the kit are too narrow, so had to cut up some new ones to fit
steve
