Author: Subject: Sealant for sump ?
mcerd1
posted on 24/10/16 at 11:40 AM Reply With Quote
Sealant for sump ?
I'm finally getting round to putting my pinto back together
I've got a crank scraper to fit (might as well) but whats the best way to seal it up ?
bottom end built :D
bottom end built :D
I've seen a few folk recommending an RTV silicon sealant - but which one is best and whats the best way to use it ?
I've used this stuff before on the the zetec blacktop - I'm assuming it would do the job...
https://www.fordpartsuk.com/shop/ford_sump_gasket_sealer_100_ml_f_1778303.htm
ot there is this stuff ?
https://www.merlinmotorsport.co.uk/p/hylomar-hylosil-100-series-silicone-sealant-85g-fl101hy-085g
posted on 24/10/16 at 11:55 AM Reply With Quote
I've not used a sealant before for a sump. When I rebuilt a Pinto for my Indy I used the gasket that came in the bottom end gasket set, which worked fine.
stripe70
posted on 24/10/16 at 12:22 PM Reply With Quote
I used this around the outside of my gasket as previously used to leak. Just incase the oil got past the gasket & it worked a treat, bone dry this time round
Pro Seal Black Silicone RTV Instant Gasket 85g
http://www.roughtrax4x4.com/black-silicone-rtv-gasket-maker.html?gclid=CPf1y962888CFUSfGwodrZoCdQ
mark chandler
posted on 24/10/16 at 12:30 PM Reply With Quote
Wurth sump sealant, get it at Halfords great stuff.
johnemms
posted on 24/10/16 at 12:34 PM Reply With Quote
REINZOSIL 70ml VICTOR REINZ Silicone Gasket Sealer Gasket Sealing Compound Seal
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
mcerd1
posted on 24/10/16 at 12:41 PM Reply With Quote
I would do - but I need something that can allow for the crack scraper and seal it to the block...
Irony
posted on 24/10/16 at 12:54 PM Reply With Quote
What he said.
ragindave
posted on 24/10/16 at 02:38 PM Reply With Quote
Dirko
DIRKO ELRING VW AUDI SEAT SKODA ENGINE SUMP SILICONE GASKET SEALANT D176404A2
perksy
posted on 24/10/16 at 05:25 PM Reply With Quote
Fittings Burton's gaskets ?
If so. are you fitting the 'heavy duty' gasket set or the standard one ?
mcerd1
posted on 24/10/16 at 09:24 PM Reply With Quote
just the standard cork ones
