Author: Subject: Alloy bellhousing
Samuele
posted on 29/10/16 at 05:44 PM Reply With Quote
Alloy bellhousing
I try to get information about this piece:
alloy bellhousing
There are two vendors who have it,
but customer service is really shit.
I expect answers to many weeks.
I wrote it and for a zetec,
but I would not buy a piece that never goes.
why I asked for clarification from the sellers.
in vain...
but maybe any of you know if and to 100% sure it's fine for a 2.0 zetec with gearbox type 9 v6
these are the links:
http://www.retro-ford.co.uk/shop/content/angliacortina-type-9-bellhousing-a003-0
http://www.ebay.de/itm/162208433620?_trksid=p2057872.m2748.l2648&ssPageName=STRK%3AMEBIDX%3AIT
posted on 29/10/16 at 05:56 PM Reply With Quote
Hmm, V6 type 9's have a longer nose so if you want to use that you'll need a spacer between it and the box...
Samuele
posted on 29/10/16 at 06:12 PM Reply With Quote
Yes,will I have to use the spacer.
I know that already.
what I do not know and whether it goes well with the engine.
the only time a seller has responded,
He told me to use a bellhousing RS2000
but no good because the cavity of d starter slams against the frame.
so I thought that a bellhousing like the ones I posted in the link,
ie the cavity of starter motor on the right to work.
posted on 29/10/16 at 06:20 PM Reply With Quote
This may be what you need but a bit pricey...
http://www.burtonpower.com/aluminium-bellhousing-type-9-5-speed-gearbox-to-v6-ford-essex-bh4a.html
This is the one I would go for...
http://www.burtonpower.com/aluminium-bellhousing-sohc-ford-pinto-x-flow-lh-starter-bh6a.html
I used the RS2000 one and yes it was a tight fit with the starter bulge being on both sides..
Samuele
posted on 29/10/16 at 06:35 PM Reply With Quote
the second bellhousing in the picture and how what I think would be suitable.
It must have only the cavity of the starter bulge the opposite side
Myke 2463
posted on 29/10/16 at 07:11 PM Reply With Quote
Check out tiger racing
Be Lucky Mike.
Davg
posted on 29/10/16 at 07:37 PM Reply With Quote
Another option will fit and as you know you will also need the spacer plate. Cheers D
http://www.rwdmotorsport.com/sierra-direct-replacement-cable-clutch-bellhousing.html
obfripper
Do you need a mirrored bellhousing due to changing your chassis to lhd?
Both the bellhousings you've listed should bolt to a zetec block fine, the one on ebay looks more heavy duty and both require a rocket gearbox clutch arm/release bearing/pivot.
The ebay one is also available in magnesium, i don't think it'll be cheap but it will be 2kg lighter than an aluminium one.
It doesn't look like either has lower bolt holes in the same position as a sierra/rs2000 bellhousing, so they will not match up to a raceline sump.
Ideally you want a copy of a lhd sierra t9 bellhousing, but i don't think that option exists unless you got a foundry to cast a copy for you and get it machined correctly.
You could chop off some of the starter bulge on a rs2000 one and tig a plate over the hole created, it wouldn't be pretty but would achieve your goal.
Dave
Samuele
posted on 29/10/16 at 07:50 PM Reply With Quote
exact, I want to move the guide to the left.
Magnesium also exists, but besides being twice more expensive,
if not mistaken, and less resistant to corrosion.
Aluminium is fine for me.
