Author: Subject: Zetec Earth Strap
Hammy360
posted on 30/10/16 at 12:05 PM Reply With Quote
Zetec Earth Strap
Do i need an earth strap on the zetec block? My existing loom from the Xflow has an earth strap to the type 9 bellhousing on the gearbox so do I need the block as well?
Hammy
Ugg10
posted on 30/10/16 at 12:14 PM Reply With Quote
I would, the better the earth, the better the spark. Also some of the sensors are earthed through the block.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Hammy360
posted on 30/10/16 at 12:27 PM Reply With Quote
Thanks mate
Hammy
prawnabie
posted on 30/10/16 at 04:43 PM Reply With Quote
I'd have at least 2 straps, if only one is fitted and it breaks, the full current will flow down components like your accelerator cable or ecc wiring to get to earth, not good whilst cranking!!
tims31
posted on 30/10/16 at 06:19 PM Reply With Quote
Yep, I have two fitted to my zetec, one near the top rear and one down by the starter motor
Build: http://www.martinsfurybuild.co.uk/
Hammy360
posted on 31/10/16 at 08:37 PM Reply With Quote
thanks gents, two it is
Hammy
