Author: Subject: Zetec - Type 9
Hammy360
posted on 31/10/16 at 08:50 PM Reply With Quote
Zetec - Type 9
Hi all,
Were 5 speed type 9's only fitted to Sierras?
If not how can I tell what car my type 9 game from?
[Edited on 31/10/16 by Hammy360]
Hammy
Hammy360
posted on 31/10/16 at 09:15 PM Reply With Quote
Heres the reason for my question, my car came with 1300xflow mated to a 5 speed type 9. Everything Im reading about RWD conversions for the zetec says you need either the sierra or RS2000 bellhousing.
As my car is a 5 speed type9 I made the assumption that that its from a Sierra, I hope I'm right
Hammy
mark chandler
posted on 31/10/16 at 09:16 PM Reply With Quote
It's a generic ford box, granada's transits p100's any ford with RWD in that era are possible.
You do not one out of a commercial vehicle really, 1st may be a waste of time.
I,m sure the more knowledgable will be along shortly.
Ugg10
posted on 31/10/16 at 09:25 PM Reply With Quote
Input shaft length and first gear ratios are the biggest give away.
Four cylinder version these are 177mm and 3.64
V6 versions are 205mm and 3.36
Lots of info here. http://www.type9gearbox.co.uk/type-9-production.html
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Hammy360
posted on 31/10/16 at 09:43 PM Reply With Quote
OK,
Further investigation proves Im ok. The bellhousing chat was all about converting escorts to Zetec and keeping the 4 speed Escort box.
Phew!
Hammy
chris
posted on 1/11/16 at 01:09 PM Reply With Quote
Yes a type 9 bolts straight to a zetec
