Author: Subject: Zetec using loom from donor car
jonathanferris
posted on 4/11/16 at 01:08 PM Reply With Quote
I am sure it may have been covered here before but I am not able to find it BUT can someone help me with my loom issue.
I am installing a blacktop zetec but as i am on a real budget I am looking at using a ford loom. If this is possible to strip back a loom from a donor car whats the procedure or how can it be done and whats the best car to get the loom and eco from?
Thanks for your help. Please go easy its my first build
Ugg10
posted on 4/11/16 at 01:32 PM Reply With Quote
I would go straight for the 2.0l if you can and nit done it myself but suspect going for the most basic model will help. That said I suspect ford use the same loom whether it is a base of a ghia, they just don't plug in the bits not needed. Are you going to be using the clocks, if so you will need to sort out the warning lights (abs/airbag) as any warning light is an mot failure. There is a "how to" thread on here somewhere.
Edit http://www.locostbuilders.co.uk/viewthread.php?tid=179921
[Edited on 4/11/16 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
tims31
posted on 4/11/16 at 01:48 PM Reply With Quote
Lots of info on here posted by big_wasa, also have look at my build site as I have posted a wiring diagram for the blacktop ecu wiring from car loom
Any probs post back
Build: http://www.martinsfurybuild.co.uk/
pekwah1
posted on 4/11/16 at 04:36 PM Reply With Quote
When i did it with a 2.0 blacktop, i used a very basic mondeo.
It was a dash out job, but started from the ECU and just stripped back the whole lot, just chopped off where it met useless stuff like indicators etc.
Then a case of stripping down the loom. If i'm honest, i didn't get rid of everything from mine or the excess wire.
As stated, big_wasa has a wealth of knowledge and there's a good how to on here somewhere "How to OEM zetec" or something like that.
Hammy360
posted on 4/11/16 at 05:16 PM Reply With Quote
Im doing this at the moment. I bought a complete Mondeo 2.0 donor and took the loom, engine, PATS and have both keys. Big Wasa and Turnipfarmer have been a massive help.
This is Warrens thread, its in the Fuel Injection Section of this forum as a 'sticky'
http://www.locostbuilders.co.uk/forum/47/viewthread.php?tid=179921
[Edited on 4/11/16 by Hammy360]
Hammy
turnipfarmer
posted on 4/11/16 at 05:35 PM Reply With Quote
you have u2u
jonathanferris
posted on 4/11/16 at 05:52 PM Reply With Quote
I remember reading somewhere that it is possible to strip a loom back to almost just a +, - and a link for the rev counter. Dont mind if i am wrong but would love to be right
jonathanferris
Originally posted by turnipfarmer
you have u2u
Yes I do
Hammy360
posted on 4/11/16 at 05:57 PM Reply With Quote
Wrong mate, but stick to what Wasa and TF tell you and theres loads of other people on here to help
Hammy
big_wasa
posted on 4/11/16 at 07:39 PM Reply With Quote
I sent a brief reply to your u2u fella. It says you havnt read it ?
jonathanferris
posted on 4/11/16 at 10:02 PM Reply With Quote
Sorry new here still navigating
snowy2
posted on 5/11/16 at 03:02 PM Reply With Quote
I have fitted the 60 pin Focus ecu to my project car... most of the info you need is here on the locost site, but if you read my posts on the Dutton forums i go into a fair bit of detail on how everything fits together..
here is a link to where the wiring starts to get sorted. FOCUS ECU WIRING
[Edited on 5/11/16 by snowy2]
sometimes you are the pigeon, most of the time the statue.
