Author: Subject: Deleting Servo
posted on 7/11/16 at 10:32 AM Reply With Quote
Deleting Servo
I want to delete the servo from a braking system.
When it comes to calculating the new push-rod length, is it simply a case of subtracting the length of the servo unit from the original?
Cheers.
It's Evolution Baby!
Dick Axtell
posted on 7/11/16 at 05:14 PM Reply With Quote
Assuming you have a servo + mcyl assy (otherwise known as a "duplex" ), the mcyl is mounted onto the servo front face. When you delete/remove the servo, the mcyl should then mount onto the face previously occupied by the servo. For practicality, I would recommend using a threaded input rod, with a suitably threaded clevis plus & lock nut. That way, you'll be able to adjust the connection to your pedal to suit the installation.
BUT - using a previously servo-boosted mcyl in a non-boosted manner, will give rise to increased pedal "feel" (i.e. increased pedal loads). You might have to change the mcyl bore size.
[Edited on 7/11/16 by Dick Axtell]
