Author: Subject: Clutch Switch
AntonUK
posted on 15/11/16 at 12:04 PM Reply With Quote
Clutch Switch
Any chance you guys running clutch switches have photos of the install that I could use for inspiration?
Thinking out loud atm, but considering wring up the clutch switch the megasquirt for a bit of launch control action.
Build Photos Here
rdodger
posted on 15/11/16 at 04:12 PM Reply With Quote
wouldn't you just use a brake switch? Perhaps one from a Mini or Sierra?
JC
posted on 15/11/16 at 06:34 PM Reply With Quote
That was my plan, if I need one, just to plumb one into the hydraulic line
AntonUK
posted on 15/11/16 at 07:31 PM Reply With Quote
It would be easy if I had hydraulic clutch, but mines cable
Build Photos Here
JC
posted on 16/11/16 at 09:08 AM Reply With Quote
My donor fiesta used a plunger activated by a tab on the pedal - not sure what your pedal box arrangement is like to know if it would work for you
CNHSS1
posted on 16/11/16 at 10:01 PM Reply With Quote
Omex do a nice clutch switch with a threaded body so you can easily adjust. An electrical switch for launch/full throttle gear shifts is better as you can adjust when it switches whereas you don't have adjustment with an hydraulic brake light switch
