Author: Subject: Clutch change.. why flywheel?
tegwin
posted on 21/11/16 at 05:03 PM Reply With Quote
Quick question..
I spoke to a local garage about getting my clutch changed. They suggested I might need to change the flywheel at the same time but they wouldnt know until they look.
Its an "old fashioned car" without a dual mass flywheel. Under what circumstances would I need to replace the flywheel? Flywheel is £200 so trying to avoid that one if I can!
www.verticalhorizonsmedia.tv
posted on 21/11/16 at 05:29 PM Reply With Quote
Fair question - I'm aware DMFs can need to be replaced, but I understood older "solid" flywheels didn't need to be. Possible I suppose that it could get damaged, but it seems unlikely. Garage covering their backside perhaps?
mcerd1
posted on 21/11/16 at 05:49 PM Reply With Quote
^^^ what he said
if its really badly scored you can normally get them re-ground too (although new may just make be to make the garages life easy)
what car / engine is it ?
tegwin
posted on 21/11/16 at 05:55 PM Reply With Quote
It's a 2001 6n2 polo gti with a 1.6 16v ebgine. An obscure model but nothing super special
posted on 21/11/16 at 06:01 PM Reply With Quote
The usual reason is because the starter ring gear is chewed, ring gear aren't available for most cars.
motivforz
posted on 21/11/16 at 06:03 PM Reply With Quote
Radial cracks normally appear in used flywheels, typically with a bit of blueing on the surface from overheating. Occasionally surface cracks (only on the friction contact region!) turn into larger cracks which will in time lead to failure.
Depending on the severity it can be worth replacing the flywheel - anything up to an inch and in the middle of the contact region, and only on the clutch side is likely to be fine - my opinion only.
Anything that's broken through to the engine side, or radiated out further than the clutch surface, is likely to be of concern and warrant either proper investigation, or more cost effective faster and easier, replacement.
Oh and the starter ring may be knackered.
tegwin
posted on 21/11/16 at 06:10 PM Reply With Quote
Hmm fair point about the starter ring. I don't have any issues starting the engine so I guess its ok...
I had better save up for the worst just incase... I would prefer to do the change myself but Its an awkward job to do on your back on a wet drive
snapper
posted on 21/11/16 at 06:31 PM Reply With Quote
Who is suggesting this?
If Mr Clutch then beware as they tried to rip me off
I've never had to change a non DMF flywheel.
I would say to them "when you've got the gearbox off I'll come and have a look"
Most garages would not mention flywheel until they had seen it.
I eat to survive
I drink to forget
steve m
posted on 21/11/16 at 06:44 PM Reply With Quote
Awaits flak
your on a bloody car forum, and you will let some bunch of cu9nts change a clutch on a golf ?
do it yourself
steve
tegwin
posted on 21/11/16 at 06:49 PM Reply With Quote
Originally posted by steve m
Awaits flak
do it yourself
steve
A valid point... and I did do it myself last time... Id love to do it myself but the gearbox is bloody awkward to get back in by yourself and its cold/raining outside.....
r1_pete
posted on 21/11/16 at 06:50 PM Reply With Quote
I agree with Snapper, tell them anything more than the clutch and you want to examine the damage yourself.
tegwin
posted on 21/11/16 at 06:52 PM Reply With Quote
A fair point!
In their defence he did mention flywheel replacement before I told him that it didn't have a DMF... But yes, I shall be very weary!!
coyoteboy
posted on 21/11/16 at 08:37 PM Reply With Quote
Never met a solid flywheel that needed replacing. Skimmed my gt4s (£40) because I'd tried to demolish it (repeated 4krpm launches until the friction plate shattered) and it showed a few blued areas but no cracking or scoring.
SCAR
posted on 22/11/16 at 08:49 AM Reply With Quote
Done a load of clutches over the years and never had to replace a solid flywheel
dinosaurjuice
posted on 22/11/16 at 09:00 AM Reply With Quote
I think the garage are just warning you that it 'might' need changing. They've probably had a bad experience with a customers car with a scored/cracked flywheel and the customer not understanding why the garage didn't know about this before the gearbox was removed.
posted on 22/11/16 at 09:01 AM Reply With Quote
Agree with your point above - doing it yourself isn't beyond your skill, but this time of year it's not a job I'd relish outside. Having to revisit to "inspect" the flywheel might add some delay, but it doesn't seem right that the flywheel should need replacing.
adithorp
posted on 22/11/16 at 12:58 PM Reply With Quote
That'd be my guess. I'm always careful to point out what is included in the estimate and that anything additional found along the way would be extra, though I'd also point out it was unlikely to need a flywheel. I have had cars that weren't supposed to be equipped with a DMF, turn out to have them when the gearbox came off.
http://jpsc.org.uk/forum/
