Author: Subject: Charge cooler setup
luke2152
posted on 24/11/16 at 11:07 PM Reply With Quote
Charge cooler setup
Charge cooler setup as pictured. Includes Charge cooler, Bosch charge cooler pump, radiator from a quad bike.
*Charge cooler has 57mm inlet and outlet pipe and 19mm water in/out. Water jacket is 100mm in diameter. Overall length 300mm. Has been drilled and tapped for a water injection nozzle and blanking plug in place now.
*Quad bike radiator. Core 300mm x 200mm x 30mm. Overall size 400mm x 200mm x 40mm. Have removed original bike in/oulets and blanked off with brass plugs. Then fitted 19mm hose tails to match pump. Mounts will need fabricating - I glued some brackets on all the time I was using it and it worked ok but not an ideal solution.
Bosch charge cooler pump. 20L/min!, 200mm long, 90mm wide at the head, 60mm wide at the body. Clamp is 125mm wide.
£160 the lot
james h
posted on 24/11/16 at 11:51 PM Reply With Quote
So tempting. What brand is the chargecooler?
luke2152
posted on 24/11/16 at 11:58 PM Reply With Quote
Not branded. Was from ebay probably from the far east
james h
posted on 25/11/16 at 12:02 AM Reply With Quote
Thanks. I need to save for Christmas, can't quite justify this at the moment.
luke2152
posted on 9/12/16 at 11:35 PM Reply With Quote
Now £130 need to get some christmas £
Don't make me put it on ebay!
