Author: Subject: Dash blanks
ChrisLeary
posted on 25/11/16 at 09:59 PM Reply With Quote
Dash blanks
Evening all,
I'm at the stage now where I need to start thinking about my dash. I haven't got a lot to spend, but I'd like to use an 'off the shelf option'.
I've looked at these after I've seen them mentioned in the forum:
http://www.plays-kool.co.uk/acatalog/Dashboards.html
Does anyone have any experience of the quality? I've read that ABS dashes are likely to warp in the sun. Thoughts?
Cheers, Chris
Don't force it! Get a bigger hammer...
tims31
posted on 25/11/16 at 10:15 PM Reply With Quote
Make one from MDF and cover it in wrap, much cheaper.
Build: http://www.martinsfurybuild.co.uk/
ChrisLeary
posted on 25/11/16 at 10:29 PM Reply With Quote
Tim, thanks for the reply.
How would you go about sealing mdf to stop the ingress of moisture?
Cheers, Chris
tims31
posted on 25/11/16 at 10:32 PM Reply With Quote
I'm using moisture resistant MDF, slight green colour but doesn't matter once covered. The wrap will also help.
See here http://www.martinsfurybuild.co.uk/LatestNews.html#oct_2016
[Edited on 25/11/16 by tims31]
ianhurley20
posted on 26/11/16 at 09:08 AM Reply With Quote
I used thin wbp ply which is water resistant then to get an IVA curve on the bottom edge cut a rainwater down-pipe vertically and pop riveted it onto the bottom edge then covered the whole thing in carbon fibre wrap (sticky backed plastic really). Very cheap and looks surprisingly effective
LBMEFM
posted on 26/11/16 at 12:32 PM Reply With Quote
As above use external ply and to make the rounded edge glue a baton flush on the bottom edge of the dash and then a half round moulding and cover with carbon fibre sheeting to make a very smooth rounded edge.
SteveWallace
posted on 26/11/16 at 02:02 PM Reply With Quote
I made mine from MDF and some scrap plastic plumbing pipe from B&Q. I went slightly complicated by making an angle in it to give me more clearance for the gear stick, but not really necessary. Just paint it to seal it and then cover it in faux leather.
painted dash blank
painted dash blank
dashboard edging
dashboard edging
finished dash (without dials)
