Author: Subject: Trying to Source Specific Brake MC
posted on 2/12/16 at 06:58 PM Reply With Quote
Evening all!
I'm trying to find a non-servo tandem brake master cylinder with a 19mm / 0.75" bore.
Easy enough you say... but I want one with either a horizontal or vertical mounting flange (rather than the more common diagonal mounting flange).
Can anyone help with finding such a thing!?
Thanks on advance.
It's Evolution Baby!
posted on 2/12/16 at 07:05 PM Reply With Quote
Triumph Spitfire or some FX4D Taxis, you could also look at very early VW Polo
gremlin1234
posted on 2/12/16 at 07:07 PM Reply With Quote
it would have to be a very late spitfire, most only have single circuit brakes
sdh2903
posted on 2/12/16 at 07:10 PM Reply With Quote
Fiat 124.
posted on 2/12/16 at 08:05 PM Reply With Quote
Cheers guys... off for a trawl through the internet to see what I can find!
Fiat 124 has a diagonal mounting flange.
Thanks for the suggestion though.
sdh2903
posted on 2/12/16 at 08:13 PM Reply With Quote
20.6mm any use?
OE Sys. Bendix Delphi Master Brake Cylinder Genuine OE Quality Braking Part
posted on 2/12/16 at 08:26 PM Reply With Quote
Not really sure about the effects of changing size?
It's for a set of Lotus Elise derived calipers (front and rear) on an un-servo'd car. I know that the original Elise S1 MC was a 0.75, but the diagonal flange used by Lotus is no use to me (and I don't want the hassle of fabricating a conversion plate).
Can anyone offer a general opinion as to how far either side of a manufacturers MC spec you can go before screwing up the performance, or pedal feel?
posted on 2/12/16 at 08:27 PM Reply With Quote
Drawing a blank with the Spitfire (0.7) and the FX4 (no reference).
posted on 4/12/16 at 11:22 AM Reply With Quote
Just on the off-chance that anyone else is looking for such a thing (unlikely as it is)... I found one!
Nissan / Datsun F10 1976-78
£112 delivered from the States. Prob £150 by the time import charges are paid, but it save me a bit of head-scratching!
posted on 6/12/16 at 12:56 PM Reply With Quote
Turns out the supplier had run out of stock... so the hunt went on!
Found this...
£65 delivered.
Result!
