New Topic New Reply
Author: Subject: adjustable top wishbones
luke2152
posted on 4/12/16 at 09:04 PM Reply With Quote
Any ideas on good ways to make front top wishbones adjustable? I'm thinking some sort of threaded sleeve in the middle of each tube (left thread on one end right on the other) that can be rotated to change the length. Was also thinking just a threaded rod inside the tube but not sure that would be strong enough.
Slimy38
posted on 4/12/16 at 09:10 PM Reply With Quote
Have a look how the Saturn MX5 plans cope with using a ball joint that fits on the MX5 upright. It's a threaded ball joint into a threaded sleeve in the wishbone. It doesn't give infinitely granular adjustment as it only works on complete revolutions of the ball joint thread. But it is adjustable.
Sam_68
posted on 4/12/16 at 09:16 PM Reply With Quote
Adjustable for what, and to what degree?
Obviously, camber adjusters are available off-the-shelf that lengthen or shorten the wishbones by a small amount:
Link
Or you can use a turnbuckle in the middle of a tube, as you suggest, if you want to be able to adjust one 'leg' of the wishbone independently (which will obviously change length and caster at the same time):
[Edited on 4/12/16 by Sam_68]
watsonpj
posted on 4/12/16 at 09:21 PM Reply With Quote
do a google search on "mcsorley adjustable top wishbone" he made a video
hopefully the linky works
looks very adjustable but don't know where to source the special balljoint but i'm sure someone will be along who can say or you can fabricate something similar.
Pete
luke2152
posted on 4/12/16 at 09:26 PM Reply With Quote
Sam your turnbuckle photo is exactly what I was thinking of. Is the turnbuckle strong enough to be safe? My main intention is to adjust castor but camber could obviously be done as well.
I actually already made a set with rod ends on all three points which are fully adjustable but you have to completely remove them to do so. And I have so many spacers where the bushes used to be that it is actually pretty difficult to achieve this. And I heard the rod ends wear out pretty quick which isn't good on a road going car.
Sam_68
posted on 4/12/16 at 09:51 PM Reply With Quote
Originally posted by luke2152Is the turnbuckle strong enough to be safe? My main intention is to adjust castor but camber could obviously be done as well.
Yes, it's strong enough, particularly on a top wishbone. That image is Googled from a Lotus Elan lower rear wishbone, where it's a routine method of providing toe adjustment.
There are problems to be aware of, mind you; obviously you won't want the locknuts to come loose, or it could go out of adjustment very easily, but also it affects castor whether you want it to or not, unless you have one built into each wishbone arm and adjust them equally (which is a pain in the butt).
You're better off using just standard camber adjusters, and/or or use rod ends set perpendicular to the centreline of the chassis on the inboard ends of the wishbones which can be screwed in or out to lengthen or shorten the wishbone.
It's also possible to use shims between a bolted connection... there are lots of ways of doing it.
Question is, why do you want to?
luke2152
posted on 4/12/16 at 10:14 PM Reply With Quote
As to the why: Well even after procomp set up everything as best as they could I find high speed bumpy roads unsettling the car to the point of being almost dangerous. Steering is just too touchy. Basically it feels like a go cart - awesome at low speeds and progressively unstable as speeds increase. With standard gbs wishbones I have 3.9* castor left and 5.2* right (not adjustable). I have since added approx 3 degrees castor to try to counter this and it helped to a degree but caused other problems (large changes in camber as you increase steering angle). So I want to set it back near to original geo with a little more castor and with the same amount on each side! (and be able to adjust it as I see fit with minimal effort).
As an aside I think my 2.8 escort rack is too fast for mx5 steering arms because I get more than 45 degrees steering angle at full lock so I should probably look at putting a standard escort rack on to tame things a bit. Perhaps a bit more toe in on the front and I have eccentric adjusters in the rear wishbone bushes (which were previously not adjustable) although I haven't had a chance to play with these.
Anyone know if I can get those turnbuckles and hardware off the shelf anywhere or if I have to make them?
Sam_68
posted on 4/12/16 at 10:37 PM Reply With Quote
Well, it's your funeral, as they say!
Bear in mind that when Lotus designed the 77 with all-adjustable suspension, not even Colin Chapman and his team of F1 engineers could sort it - there were just too many variables involved. The more complex you make the adjustments, the more you'll end up chasing your own tail.
With a turnbuckle arrangement, every time you make an adjustment to the wishbone length, you'll be throwing out the castor setting at the same time. You're far better off coming up with an arrangement that adjusts wishbone length (camber) and castor independently of each other (eg. camber by off-the shelf camber adjusters, caster by shimming the wishbones fore-or-aft relative to the chassis mounting brackets).
luke2152
posted on 4/12/16 at 10:49 PM Reply With Quote
You're probably right Sam - I will end up chasing my tail. But there's really only two variables - camber and castor. Set the castor by fiddling with the lengths of the tubes. It puts the camber out. But then you correct the camber again using only the rod end closest to the wheel. (If I'm wrong on this I'm happy to be corrected!).
Sam_68
posted on 4/12/16 at 11:17 PM Reply With Quote
...one of which (castor) you'll ultimately want to set, and stay set, the other of which (camber) you may wish to be more readily adjustable.
Honestly; do it the normal way, keeping the adjustments independent of each other. There's a good reason that it's the normal way. If adjusting the wishbones by means of turnbuckles in the middle of the wishbone arms was a clever idea, everybody would be doing it!
Have you checked bumpsteer?
Camber Dave
posted on 5/12/16 at 08:57 AM Reply With Quote
Another vote for Bumpsteer
Mash
posted on 5/12/16 at 10:27 AM Reply With Quote
Is this normal?
I'm probably talking rot, but could you not adjust it with the adjustable set you've made already so that both sides are the same, make the adjustments you want as close to original as possible, then alter the standard ones to the size they should be, copying the adjusted ones, then put the standard (now modified) ones back on. From then on, normal camber adjusters as suggested above?
russbost
posted on 5/12/16 at 10:33 AM Reply With Quote
Before you go into loads of work, have you tried adjusting tracking to see what effect that has & also what tyre pressures are you running with what size tyres.
I know it's a very different car, but with the Furore, if you run ANY toe out it destroys the driveability of the car, as long as it toes in, it doesn't really seem to matter how much, I normally run around 1 - 2mm toe in. We do run an enormous amount of castor, so as I say a very different setup to a 7
If tyre pressures are high (particularly at this time of year & particularly if you low profile tyres) then you'll find the thing hopping all over the road
Fred W B
posted on 5/12/16 at 06:20 PM Reply With Quote
South African built Birkins have a neat solution for camber adjustment, as shown in the picture, although they use a top ball joint, not a rod end.
The top upright attachment incorporates a internal and external threaded bush between the left hand 1.5 mm threaded 16 mm rose joint and the bush that will be welded into the top wishbone. A 360 deg rotation gives 3 mm of movement. The black half nut is the locknut on this adjustment bush, the lock nut on the rose-joint is not fitted yet.
Fred W B
[Edited on 5/12/16 by Fred W B]
luke2152
posted on 5/12/16 at 09:25 PM Reply With Quote
I'm not really sure how to check bump steer. I guess I could remove the struts and measure the toe in through the range of suspension travel.
I have 1.5mm of static toe on the front. Not sure about the back at the moment. Tyre pressures 20psi on T1R 195/45/14
New Topic New Reply
