Author: Subject: Re-Using Balljoint
posted on 14/12/16 at 01:45 PM Reply With Quote
Re-Using Balljoint
So, you've switched off for a mo, and inserted a balljoint through the wrong side of the wishbone!
I've pressed it back out - can I re-use it and put it back in (the right side!).
It's Evolution Baby!
bonzoronnie
posted on 14/12/16 at 01:50 PM Reply With Quote
If there is no damage to the joints taper or rubber boot, I can see no reason as to why you cant re-use the joint.
posted on 14/12/16 at 02:12 PM Reply With Quote
I'd say the same TBH if you've not damaged the taper or boot then I'd refit the right way.
r1_pete
posted on 14/12/16 at 02:58 PM Reply With Quote
Again I see no reason why not, it hasn't started to bed in (or wear out if you prefer) so no reason not to re seat it the right way round.
posted on 14/12/16 at 04:19 PM Reply With Quote
You mean the type that a serated shoulder that is pressed into the wishbone ? ----just use a permanent grade of Loctite
posted on 14/12/16 at 05:31 PM Reply With Quote
One of these...
... and I'd just refitted them before reading your post.
Should I remove and refit.. again... with loctite?
posted on 14/12/16 at 07:32 PM Reply With Quote
If it is snug just leave it be.
[Edited on 14/12/16 by britishtrident]
posted on 14/12/16 at 07:42 PM Reply With Quote
Cheers!
wylliezx9r
posted on 14/12/16 at 07:48 PM Reply With Quote
Driving an Elise now scootz or a vx220 maybe ?
George Best
posted on 15/12/16 at 08:26 AM Reply With Quote
Yeah - back to a Lotus
b14wrc
posted on 21/12/16 at 12:13 PM Reply With Quote
I miss my Elise some times....
Any photos Scootz?
I did all my wishbones about 6 months before selling mine, I found they had to be pressed in with quite a bit of force so should be fine.
[Edited on 21/12/16 by b14wrc]
20vt powered rear engined locost
