Author: Subject: First post
johnhsmith
posted on 19/12/16 at 11:47 PM Reply With Quote
First post
I'm new to the site and this is my first posting. I hope it's not too boring!
I bought the Ron Champion book nearly 20 years ago in the hope of building a sports car with my young son. Money, space, time and divorce all conspired to thwart my plans and the book went into hibernation. We now have a business making parts for classic cars, and new premises mean that I have around 1500 sq ft SPARE to play in. Joy!!
I dug out the book from the loft and was tickled to read that a Mk 1/2 Escort could be bought for £25.00. Those were the days!
The new book was soon sourced along with a nice Sierra 1.8 for £600.00, and I'm off!
Work is very busy so I only get an hour a day, plus a day some weekends. I started 2 months ago and am now ready to fully weld the chassis and start stripping the Sierra.
Although there are so many 'head scratching' moments, I soon saw that you just have to get on with it using your initiative and ignoring the book discrepancies.
But you knew there had to be a question, and here it is.......
The suspension bushes fit into the wishbone tubes with the crush tubes in the centre. The term 'crush tubes ' suggests that the bolts tighten the brackets onto the crush tubes, thus the crush tubes do not move with the wishbones. So when the suspension is active, do the wishbones swivel on the rubber bushes, or do the rubber bushes swivel on the crush tubes? If the former, I'll have to grind out the seam joint on the inside of the wishbone tubes as they would tend to grind away at the rubber bushes.
Or....
Do the bolts not tighten the brackets onto the crush tubes and rely on lock nuts so that the wishbones, bushes and crush tubes swivel on the bolts?
I hope this makes some sense.
I'll post some pics if anyone is interested
John
Sent from John's iPad
adithorp
posted on 20/12/16 at 12:14 AM Reply With Quote
Bolt tighten on crush tubes and the bushes turn on the crush tube.
http://jpsc.org.uk/forum/
ReMan
posted on 20/12/16 at 07:44 AM Reply With Quote
As above :-)
Welcome aboard. Yes we're always interested.
So posting some pictures. (its part of the LCB initiation)
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
Nickp
posted on 20/12/16 at 08:10 AM Reply With Quote
As above, the bush swivels on the crush tube. There's several 'debates' on here of the best way to achieve this. I chose to use a stainless washer just slightly bigger than the crush tube at each end of it. This stops the bush sliding off the tube and minimizes the friction on the bush as it isn't clamped in the bracket. Just my opinion of course
I've gone a similar Haynes / Sierra route but wasn't happy using the Ford engine so went BMW
http://www.locostbuilders.co.uk/viewthread.php?tid=198679
907
posted on 20/12/16 at 09:20 AM Reply With Quote
This may or may not help but I had two problems with my w/b bushes.
I bought enough for the front and back w/b's but found that the flange on them varied in thickness. This meant that
when inserted into a bush tube the overall dimension varied, making some assemblies longer than a crush tube.
I could have paired them up, a long with a short, and got them within reason, but opted instead for turning them in
the lathe so all were identical. When assembled in a bush tube the overall dimension was 0.3mm shorter than a crush
tube. All components now identical and universal.
When I welded my bones what was a "push in with the thumbs fit" became a "squash in the vice fit" due to weld shrinkage.
If you squash a flexible bush into a bush tube then you shrink the internal diameter, so what was a perfect fit on the crush
tube became a wee bit tight. I therefore reamed the assembled bushes with a suitable drill, in my case a 9/16".
This only removed a mere shaving but was enough to allow the crush tube to be inserted and turn freely.
After filling the gap between the bushes with grease and assembling on the chassis each wish bone could be lifted with
one finger, and would slowly drop under its own weight.
Hope this helps.
Paul G
Irony
posted on 20/12/16 at 11:18 AM Reply With Quote
As above, the crush tube has to be slightly longer so the suspension bracket doesn't bind on the bushes. If it does bind you end up with creaky suspension. Which is quite common on these cars.
SCAR
posted on 20/12/16 at 12:03 PM Reply With Quote
A small and pedantic detail but you describe your bushes as rubber. The above replies seem to refer to the use of poly bushes which are designed to rotate about the clamped up crush tubes. If you have the isolastic type RUBBER bushes your wishbone movement is provided by the FIXED rubber element deforming under load rather than any free rotation around the central crush tube. This means with iso bushes you cannot bolt up the crush tube until the suspension is resting under load. The two systems feel quite different when setting up. With no load the poly bushes set up should move as described in one of the above posts. When you tighten up the isolastic system the wishbones should stay in place and will resist movement as the rubber element has to deform.
The resistance to movement in the iso bushes will therefore contribute to the suspension set up Poly bushes should be passive
Try and avoid petroleum based grease for polybushes, many people have used it without issue but its not recommended.
When pressing poly bushes into the wishbone tubes DO NOT apply any type of grease. The poly bush to tube fit should be tight and dry to prevent any movement, if you need to aid pressing in use soapy water only, this will dry out and leave you with a nice tight fit. Grease is the last thing you want in a fixed interface.
[Edited on 20/12/16 by SCAR]
bi22le
posted on 20/12/16 at 01:15 PM Reply With Quote
This is an important post as this changes the set up.
Another thing that has not been mentioned, but is in the same area, is the bracket hole \ crush tube ID and bolt OD. Generally speaking the bushes are imperial (modern polys are probably metric) and these require imperial holes and imperial bolts. If you use a metric M12 in a imperial 1/2" bush and hole you can get a fair amount of slop, even once it has all been tightened up.
Check you crush tube ID and match this with the holes drilled on your chassis brackets and bolts.
Please read my ring story:
johnhsmith
posted on 20/12/16 at 11:07 PM Reply With Quote
First Post - Wishbone Bushes
Firstly, thanks for all your interest, support and replies.
I will post some pics when I can, possibly over the Christmas break.
I can see that there has been a few issues with this subject before which makes me feel a little less stupid.
Scar - yes you are correct, I said rubber but meant Poly.
It seems obvious to me now that the bushes rotate on the tubes, so thanks to all of you for putting me straight on that.
bi221e - yes, I have already spotted the issue with hole/bolt sizes. I had the brackets laser cut to book sizes. Not only we're all the development sizes out, but there was obviously an issue with 12.5mm holes in the brackets and 12mm holes in the crush tubes. I had them re-cut to correct sizes and 12mm holes.
I'm just starting to look at the rear uprights and I know that there are going to be problems. Again, I had the blanks laser cut to book drawings, and I've just noticed that RU8 has 4 holes tapped M10 and I'll bet they've done the as 10mm holes! I'll check tomorrow.
Again, thanks to you all and I really enjoy reading all your stuff.
John H S
bi22le
posted on 21/12/16 at 12:06 AM Reply With Quote
Put your location up so people know where your from.
mark chandler
posted on 21/12/16 at 06:59 AM Reply With Quote
Metalastic rubber bushes should be assembled loose, when the car is completed and sitting on its 4 wheels then you nip the bolts up.
johnemms
posted on 21/12/16 at 12:18 PM Reply With Quote
Get a Zetec 2.0 engine from scrap yard and consider a six speed RX8 gearbox eBay scrapyard..
Make your chassis to fit a modern engine & box..
Happy Christmas
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
johnhsmith
posted on 30/1/17 at 11:46 PM Reply With Quote
Not easy is it!
Sorry it's been so long since my last post, and it's not that I've been busy on the Roadster, but work and other stuff.
I made up the rear uprights and sure enough, RU8 had not been cut with holes for tapping M10, but 11mm! They've recut them (foc) now so I've finished them off now and ready to fettle and paint.
The diff came off the Sierra ok and is cleaned up and ready for painting later on. The half shafts were not a problem when driving the Sierra, but 3 of the boots are spit in 2 pieces. (Is that an mot fail?)I decided to get new shafts from my local suppliers (J&R) but they don't seem able to match them yet. I don't know what to do on this as to renew the boots seems like a massive job!
I was expecting to need to alter the length of the shafts, as per various stuff I've read, but they seem to be ok and I'll check that when the uprights are finally done. Of course, if I'd had to alter the length by cutting and re-welding, I'd be able to easily fit new boots.
The problem with matching the shafts seems to be that the Sierra is H Reg with what l think is R2A engine, they're saying it's R6A. All gobbledygook to me!
Update
J&R finally gave me a pair of half shafts but they were too big to go through the back plates or uprights, and they were slightly too long so the wishbones wouldn't move fully, so I returned them for a full refund. I'll have to fit new boots to the old shafts, the split sort, so I don't have to fully strip the shafts.
After reading plenty of stuff on the forum re reaming front hubs, I ordered a 19mm taper reamer from Axminster. I worked out that it is about 13degrees, and the Maxi balljoint is around 6 degrees, so that's going back as well.
Does anyone have any ideas where I can borrow/hire/buy the correct reamer?
Christim's build looks spookily similar to mine!!
I can't work out how to upload pics, but I'll have a go tomorrow
40inches
posted on 31/1/17 at 09:59 AM Reply With Quote
Fitting new boots is fairly easy using stretch boots. They come with grease and a cone to stretch them over the UJ
mcerd1
posted on 31/1/17 at 10:50 AM Reply With Quote
First off - I assume your driveshafts look like this:
these are whats known as the 'push-in' style shafts on a sierra (don't expect any motorfactor to know what that means though )
they were used on all he sierra's with rear drum brakes, but I believe they come in 2 - 3 different diameters and a few different lengths depending on the age and spec of the car...
they use "tripod" CV joints and there are several old threads on here about sourcing boots and rebuilding them
here's one of them: http://www.locostbuilders.co.uk/viewthread.php?tid=173535
the sierra's with rear discs use a totally different driveshaft and CV that bolts on (known as a Lobro joint)
googling suggests a R2A and R6A engines are both 1.8 CVH's - which should look a bit like this:
google says the R2A is a 66kW with a Pierburg 2V carb and no cat, but the R6A is the injection version from ~92 onwards
more details on the basic engine underneath all that here:
http://www.burtonpower.com/tuning-guides/tuning-guide-pages/ford-cvh-tuning-guide.html
the VIN plate would tell you the actual engine code your car had when new - but its probably not going to help you get the right driveshafts, ford seem to have done alot of mixing and matching towards the end of the sierra's production.....
this site has loads of info to help you ID the actual parts you have / need:
http://www.super7thheaven.co.uk/components/sierra_rear_drive_shafts/
jps
posted on 31/1/17 at 11:31 AM Reply With Quote
Re: hubs. Search on here, there was a thread recently from someone trying to find a reamer, turned out there was a company in Birmingham that had the right tool and could do the work. Probably better vfm than buying the tool just to use once!
jps
posted on 31/1/17 at 11:39 AM Reply With Quote
Here you go, link to the LCB thread is in this thread on the Haynes forum: http://forums.haynes.co.uk/archive/index.php/t-13981.html
I think Procomp generally have a good rep on here and do shocks/ geo setup so perhaps you'll use them further on in your build too...
johnhsmith
posted on 31/1/17 at 10:59 PM Reply With Quote
mcerd1
Yes, just like that but very rusty.
As I said, there didn't seem to be any problem with the driveshafts apart from the split boots, so I was hoping to do without a total rebuild. £140.00 for shiny new shafts seemed like a good idea as I'm time poor.
I've now ordered split boots so I don't have to dismantle the whole things.
johnhsmith
posted on 31/1/17 at 11:07 PM Reply With Quote
Thanks for that JPS, I can't believe that there is a company that might be able to do the uprights within 10 minutes drive from home. I've never heard of them but I'll contact them later this week when I get the uprights back from shotblasting. I needed a good result on something!
40inches
posted on 1/2/17 at 08:41 AM Reply With Quote
mcerd1
Stretch boots are superior to split boots.
