Plunky
posted on 20/12/16 at 03:13 PM |
Master Cylinder
Hi, I'm looking to upgrade the master cylinder on my F27. I am looking for a firmer pedal.
Pictures of the current cylinder below.
Any suggestions?
[URL=http://s194.photobucket.com/user/plunky999/media/IMG_0664.jpg.html][/URL
[URL=http://s194.photobucket.com/user/plunky999/media/IMG_0666.jpg.html][/URL
Dick Axtell
posted on 20/12/16 at 04:03 PM |
That looks like 74660018 on the mcyl body. That's the casting part number. Could be an old Fiesta mcyl. Will check my info. Do you know what
your bore size is?
Plunky
posted on 20/12/16 at 04:27 PM |
No idea on the bore size.
Is there an easy way of measuring this?
posted on 21/12/16 at 07:07 AM |
If you have excess pedal travel check the rear adjusters haven't slipped back -- you can usually hear the brake shoes move if they have and
check for seized piston in the front calipers.
On M16 calipers a stuck pston or pad gives excess pedal travel -- it has distictive springy feel. With a stuck piston the pedal travel increases as
the pads wear unevenly.
The same symptoms occur if the guide pins are seized with Sierra style floating calipers also if the spring retaing clip is not fitted properly.
[Edited on 21/12/16 by britishtrident]
Dick Axtell
posted on 21/12/16 at 03:32 PM |
Girling mcyl p/n appears to be 74066009 (for the assembly), and according to records is 22.2mm ID. Cannot locate which vehicle it was originally
fitted to.
Plunky
posted on 17/1/17 at 04:14 PM |
Does anyone know what I can replace with?
