Author: Subject: Christmas question - affordable supercharger.
Ugg10
posted on 24/12/16 at 11:22 PM Reply With Quote
So, if you can't afford a rotrex/vortex has supercharger, and don't like the roots/eaton chargers, could you use a seadoo jet ski one on a car engine. (Similar centrifugal design).
So take say a puma 1.7l engine with a bit of work done, revs to 8k and pushes out 175hp.
The new seadoo engines are a rotax design with 1.5 - 1.8l, rev to 8.5k and push out between 185 and 300hp. They are supercharged and the top end push out 18psi but the charger does not need a lubrication system, they seem to be sealed/non maintenance systems. The drive will need sorting as they are cog, not belt/wheel driven, but not a difficult job.
So, for $500 you can get a low hours sh charger shipped and taxes to the uk, so what is the snag with putting one of these on something like a puma 1.7 engine (assuming you have an ecu to run it)?
Example 2004 Seadoo Supercharger RXP 215
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
bi22le
posted on 25/12/16 at 01:43 AM Reply With Quote
Well a 5 min search suggests that they need rebuilding after 100 goes of use. Also rotax a 2 stroke so the demands on a supercharger are completely different.
Please read my ring story:
Ugg10
posted on 25/12/16 at 08:24 AM Reply With Quote
Thanks for the reply, this is the mid/upper range engine that I was thinking of, 4 stroke.
https://www.rotax.com/en/products/rotax-powertrains/details/rotax-1503-ho-4-tec.html
Did a search and as you say 100hrs use rebuild but looks like it has some sort of crush washer clutch thing on the shaft which wears. Not sure this will be needed if you stick a pulley on it?
posted on 25/12/16 at 04:58 PM Reply With Quote
Rotax made lots of four stroke engines. They even made the Aprila RSV Mille V-twin that powered Froggy's Reliant Kitten.
