Author: Subject: LSD axle
donn006
posted on 28/12/16 at 11:26 AM Reply With Quote
LSD axle
Hi after lots of googling ,trying to get a di Dion set up ,I'm not having much luck .so I'm now thinking heather to stick with the live axle set up but I would still want to get an lsd axle any ideas on what would fit and be strong enough to take 300+ bhp as that's what I've got at the moment and running a cortina axle
big_wasa
posted on 28/12/16 at 12:17 PM Reply With Quote
The cortina could have been fitted with three different axles, English, Atlas or Koln. You can get lsd's for the first two not sure about the Koln.
It's most likely to be an atlas and it's the strongest and heaviest of the three. "Daveb666" runs 300bhp through a 1.6 Capri atlas with a plated diff from a Capri 2.9 special. It's the only Oem option but you can get aftermarket. Maybe worth a chat.
donn006
posted on 28/12/16 at 12:24 PM Reply With Quote
LSD axle
The axle fitted is the one which the diff build into the axle and not the one that bolts off and it's not fitted with a lsd
big_wasa
posted on 28/12/16 at 12:36 PM Reply With Quote
That could still be an Atlas or a Koln. Would bet it's an atlas.
Oddified
posted on 28/12/16 at 01:25 PM Reply With Quote
Take a picture of the rear cover, the shape and spacing of the bolts is different between the atlas and koln.
As said by big wasa, it's more than likely an atlas.
Ian
chillis
posted on 29/12/16 at 01:31 PM Reply With Quote
Won't be an atlas if it came from a Cortina. MK1&2 had English, MK3,4&5 had Koln. You may find a rare South African V8 'tina with an 8inch.
Never under estimate the ingenuity of an idiot!
