Author: Subject: Clutch / diff judder
flanders
posted on 28/12/16 at 07:06 PM Reply With Quote
Got my zx12r running last week and took it out for a shakedown. All is well except I'm experiencing a heavy vibration in the drivetrain when pulling away in first gear.
This is a new noise since fitting the new engine.
I've tried 2 different clutches and different sets of springs. And it's still there.
Things in the drivetrain that have changed since engine swaps-
Prop has been shortened (I did force the prop in place putting pressure on the diff input flange before having it shortened 25mm )
Prop has increased angle from the centre bearing
No changes to the diff (Sierra LSD) itself but the noise sounds likes it's coming from there
The clutch works fine once rolling, no noises etc, it's only whilest pulling away from a stand still
Any help on this would be appropriated as I'm struggling.
My thoughts now are a diff issue (is it maybe just locking up with the increased torque?) or something like the clutch basket.
loggyboy
posted on 28/12/16 at 07:19 PM Reply With Quote
Sounds like clutch/flywheel alignment issue or a warped or uneven material deposited on the fly wheel.
I had a similar issue after my last clutch was changed on clio, when i replaced the box a few months back, i gave fly wheel a light rub down and carfully relocated the clutch and it went away.
[Edited on 28-12-16 by loggyboy]
Mistral Motorsport
flanders
posted on 28/12/16 at 07:29 PM Reply With Quote
I don't have a flywheel bud...it's a bike engine
I should also say that if I'm very very slow and careful with the clutch it vibrates much less.
ian locostzx9rc2
posted on 28/12/16 at 08:11 PM Reply With Quote
Sounds like it maybe a clutch issue then
Toprivetguns
posted on 28/12/16 at 08:36 PM Reply With Quote
Prop not balanced or worn centre bearing that is now more apparent due to changing positions/modifying length?
Only drive as fast as your angel can fly... !
ReMan
posted on 28/12/16 at 09:10 PM Reply With Quote
have you replaced the clutches complete, including the basket? If not I wonder if the clutch centre is failing.
I doubt the prop it the issue at such low speed unless you've really put a strong angle on it
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
flanders
posted on 28/12/16 at 09:20 PM Reply With Quote
Not the clutch basket, just the fibres and steels. It was exactly the same with both clutches., One oem and one was updated.
When the prop was shortened it wasn't re-balanced but I'm thinking the same...such low speed shouldn't be noticeable if it's out of balance but I'm certainly no expert here.
CosKev3
posted on 28/12/16 at 10:14 PM Reply With Quote
Deffo a clutch issue,propshaft would be at higher speeds,and diff would be all the time not just as you are taking up drive.
I had it with the original clutch in my R1 engine where I had not noticed the diaphragm Spring was meant to be fitted in a certain position.
Have you followed the tightening procedure up correctly on the clutch springs?
mark chandler
posted on 28/12/16 at 11:02 PM Reply With Quote
Is the clutch basket notched where the steels and plates move out, this would lead to poor take up.
CosKev3
posted on 28/12/16 at 11:08 PM Reply With Quote
Yeah good point.
You can file the basket down to make them smooth again
flanders
posted on 28/12/16 at 11:15 PM Reply With Quote
I've not checked the basket to be fair, so remove the clutch and look for imperfections on the basket?
CosKev3
posted on 28/12/16 at 11:30 PM Reply With Quote
Yeah where the square side pegs on the clutch plates sit in the slots on the basket.
You might find small dips/worn parts,the plates should be able to slide out smoothly but if there are indents they can catch on these and not release smoothly
r1_pete
posted on 29/12/16 at 02:26 PM Reply With Quote
Also check all your engine mountings are sound and tight, could be the torque reaction moving the engine on its mounts as you take up drive.
flanders
posted on 31/12/16 at 10:27 AM Reply With Quote
Ok so...took the car out for another drive yesterday.
Noticed a few things
My prop is definitely needing balanced as I'm getting a vibration around 60/70 mph.
The heavy vibration at take off is worse once the engine is hot
If I'm super careful with clutch control- not easy in a Bec i.e nice and slow with lower revs whilst pulling off, then it's much better
Diff has plenty of clean oil.
Other stuff if found out...
The ZX12r A1 engine can suffer from poor clutch lubrication, drilling the basket can help this.
It also has an 'anti judder' spring and spacer between the first friction plate and steel, this is in place and fitted correctly but I'm going to replace it just in case
It's a strange one, but I'm trying not to just throw parts at it aimlessly
Il will get the prop balanced and do the judder spring for starters.
CosKev3
posted on 31/12/16 at 10:51 AM Reply With Quote
It's Deffo a clutch issue then if engine heat alters it.
Are the plates/steels new?
Have you got enough engine oil in it?
flanders
posted on 31/12/16 at 11:00 AM Reply With Quote
Yup, sight glass is full when cold so if anything it's maybe a little over filled. The engine sits ever so slightly nose down in the chassis, I've had the sump shortened, baffle plate Fitted
I'm suspicious of this clutch lubricating issue that the A1 could suffer from.
Have a wee look at this link - http://kawasakiworld.com/racing/37186-not-enough-oil-clutch-pack-how-fix.html#/topics/37186?page=1&_k=4pepjn
Although I don't want to send myself on a wild goose chase if it's something simple (oil level or judder spring)
The oem clutch which is in it now isn't new but the other clutch I tried was new, so I've tried 2 full clutched (steels and friction) and the issue is no different
The issues wasn't present with my old engine and the bike ran fine before I broke it, although I think the extra weight of the car is probable exaggerating the problem since it's a take-off/loading issue
[Edited on 31/12/16 by flanders]
CosKev3
posted on 31/12/16 at 11:09 AM Reply With Quote
How much have you had taken off the sump?
flanders
posted on 31/12/16 at 12:31 PM Reply With Quote
They said approx 30mm, and increased lost capacity sidewards
flanders
posted on 3/1/17 at 10:12 AM Reply With Quote
ordered new clutch pull rod, pull lever, needle bearing, judder spring and washers.
when im back in there ill inspect the grooves in the basket and probably do the oil supply mod in the link above, also getting the prob inspected and re-balanced fingers crossed
