Author: Subject: zetec to type 9 gearbox
dynamo dave
posted on 30/12/16 at 04:58 PM Reply With Quote
hi all im new to this
right I have a problem ive mated 1.8 zetec on bike carbs to a type 9 gearbox now there doesn't seem to be anywhere to fit the starter motor
any advice would be great
[Edited on 30/12/16 by dynamo dave]
pekwah1
posted on 30/12/16 at 06:25 PM Reply With Quote
Help USB out, is it a blacktop ir silver top zetec? (Denoted by colour of rocker cover)
On the blacktop you need to remove some of the webbing part of the top section of the sump
r1_pete
posted on 30/12/16 at 06:50 PM Reply With Quote
Yes you need to cut a lot of webbing away on a blacktop sump, heres one I did
starter2
starter2
Heres the mods I needed to do to a silvertop sump
Phase 2 sump on phase 3
Starter is a qx components qs1221, lucas lrs707 equivallent.
dynamo dave
posted on 31/12/16 at 10:01 AM Reply With Quote
Hi sorry it's the blacktop engine
R1_pete your a star that's the info I was after and the pics thank
Obviously the sump has to be taken off to cut the webbing back
pekwah1
posted on 31/12/16 at 11:54 AM Reply With Quote
The sump doesn't need to come off for that, I hacked off all the webbing with a hacksaw and hammer with the sump in place.
You will want to modify the sump in any case to have some ground clearance.... I'll be taking off the bottom section only and doing the diy job listed on this site somewhere..
