Author: Subject: Deburring? (Especially on the 'inside'?)
jps
posted on 30/12/16 at 06:40 PM Reply With Quote
Can anyone recommend suitable tools and/or techniques for deburring holes I've drilled in order to rivet panels on? I'm especially wondering how I deburr inside the chassis rails, or if that is actually possible? Holes are 3.2mm so not a lot of room to get a tool in!!!
Toprivetguns
posted on 30/12/16 at 06:51 PM Reply With Quote
I've always used this tool. It also has interchangeable blades.
https://www.cromwell.co.uk/shop/cutting-tools/deburring-sets/ng1003-noga-burr-3-set/p/NOG1096150E?utm_campaign=pla+-+&utm_source=google&utm_me dium=shopping-pla&utm_keyword=NOG1096150E&istCompanyId=6aa6787b-063e-4414-802d-129f235df603&istItemId=xxwritllxt&istBid=tztx
Only drive as fast as your angel can fly... !
bi22le
posted on 30/12/16 at 06:55 PM Reply With Quote
Yup. That is what I would use. Its great for all metals and plastics.
Please read my ring story:
big_wasa
posted on 30/12/16 at 07:04 PM Reply With Quote
Yep me three.
gaz_gaz
posted on 30/12/16 at 08:49 PM Reply With Quote
Google EZ Burr.
That's what I use for back deburring holes.
Bluemoon
posted on 31/12/16 at 08:03 AM Reply With Quote
I also use these but had to grind down the back of one of the tools to do the back of 4.1mm diameter holes (my Avex multigrip rivet size), not sure they do a blade for blind holes of diameter 3.2mm.
Dan
myke pocock
posted on 31/12/16 at 10:08 AM Reply With Quote
In a blind hole don't be too aggressive in case the tool comes out of the holder and slips into the hole, never to be seen again. Why do I know? You guess.
[Edited on 31/12/16 by myke pocock]
jps
posted on 31/12/16 at 09:04 PM Reply With Quote
Originally posted by gaz_gaz
Google EZ Burr.
Looks like the tool to have - where did you get yours from? Finding it a bit awkward to work out if there are UK stockists..?
jps
posted on 14/1/17 at 09:30 PM Reply With Quote
Does that allow you to debur the 'blind' side of a hole though? Concerned about clearance as my holes are only 3.2mm
jps
posted on 7/2/17 at 08:23 PM Reply With Quote
Still haven't bought a tool for this, anyone got experience of using one of these - which appears to be the UK-available version of the EZBurr...?
rc1000 deburring tool
Bluemoon
posted on 7/2/17 at 11:10 PM Reply With Quote
looks good if the do the size you need.. will not be cheap as quality brand..
