Author: Subject: Where to fit coolant gauge sender?
flanders
posted on 3/1/17 at 10:19 AM Reply With Quote
Due to a lack of fittings on the engine im going to fit a coolant temp sender using an in-line adapter in my radiator hose, should i be monitoring the hot flow into, or cooler return from the radiator?
im thinking the flow in side, as close to the engine as possible?
Im aware that i wont be getting accurate temps until the stat is open but thats when i want to be monitoring the temp anyway
SPYDER
posted on 3/1/17 at 10:26 AM Reply With Quote
Hi there. I fitted mine into the outgoing pipe to tell me how hot the engine is actually running. (Once the thermostat is open).
flanders
posted on 3/1/17 at 10:32 AM Reply With Quote
outgoing from the engine to the rad? if so thats what i was thinking, do you get an accurate reading once the stat is open?
CosKev3
posted on 3/1/17 at 11:34 AM Reply With Quote
I welded a boss into my thermostat housing before the stat,as this is where coolant temps are taken from on engines that have a coolant temp gauge as standard
flanders
posted on 3/1/17 at 11:56 AM Reply With Quote
I can't weld I'm taking the easy option
flanders
posted on 3/1/17 at 12:03 PM Reply With Quote
Unfortunately the zx12 only had one sensor which feeds the dash and ecu so I'll need to leave this in place for the ecu to read engine temps. And I can't see any other threaded blanks I can use
CosKev3
posted on 3/1/17 at 12:23 PM Reply With Quote
Will work fine in the pipe after the thermostat,will just seem as if the engine is slow to warm up though looking at the gauge
posted on 3/1/17 at 12:45 PM Reply With Quote
If no room in the thermostat housing the next best place is in the by-pass plumbing.
big-vee-twin
posted on 3/1/17 at 07:04 PM Reply With Quote
Mines in the top hose, feeding the rad, it doesn't show much temp til the thermostat opens, but I like it like that as it confirms stat open and water flowing. Megasquirt uses sensor at the back of the head. You can see it on the pic below.
[img] Jenveys
Jenveys
[/img]
http://www.triangleltd.com
flanders
posted on 3/1/17 at 11:08 PM Reply With Quote
Brilliant thanks for the help fellas
