posted on 4/1/17 at 10:03 AM |
Fitting a towbar in rusty holes
My Jeep has not had a towbar fitted for 12 years, and now the mounting threads in a chassis rail are rusted beyond use. I'm thinking of drilling
it up and replacing it with an m12 thread. Anyone done this, or any dire warnings? I can't see an alternative tbh.
designer
posted on 4/1/17 at 10:23 AM |
Just run a tap through it.
posted on 4/1/17 at 11:41 AM |
That would be my first action - lube it and run a tap through to clean the thread.
The difficulty I see with drilling /tapping it larger is ensuring the drill / tap run squarely through the material. Out of interest what is the
existing thread...M10?
posted on 4/1/17 at 02:13 PM |
Yeah m10. I got a bolt into it fine, but it wobbles even when fully through. The threads have rusted away, not just rusted up. In the process now of
tapping it to m12.
posted on 4/1/17 at 02:54 PM |
Fair enough - I assumed the existing thread would be rust covered.
posted on 4/1/17 at 03:45 PM |
Can you get to both sides of the rail? If so, why not thread a longer bolt through and back it up with a nut?
907
posted on 4/1/17 at 04:45 PM |
tapping it to m12.
Tapping to M12 is the way Joel.
!0.2mm is the drill size and this will take the old thread out completely.
Just make sure there's enough metal remaining after the M12.
llionellis
posted on 4/1/17 at 06:27 PM |
Depending on age it could be UNC 10mm bolt would be slack (very slack) in a 7/16 unc tapped hole.
bi22le
posted on 4/1/17 at 06:58 PM |
Its a 12year old Jeep. This was my thinking when I first read this. It won't be M10!
Please read my ring story:
coyoteboy
posted on 4/1/17 at 11:17 PM |
Interestingly a search through forums suggests the engine and transmission bolts may be metric but a lot of the body bolts are UNC.
posted on 5/1/17 at 08:58 AM |
I hadn't considered this and it could be on the money. If the hole is now drilled then tapping to M12 may be the only resolution.
As mentioned a nut on the other side could increase security of the fixing. Would a plain (untapped) hole then be batter?
posted on 5/1/17 at 08:32 PM |
It'lll be fine in that plaice.
steve m
posted on 5/1/17 at 09:03 PM |
Am I not the only one, who thinks, "the holes are so rusty that the bolts pull through" and .................
If so the metal around, the said rusty threaded holes will be so rusty, that its wafer thin, the first tug on the towbar will rip the whole rear
end of the car ?
maybe, its just me then
gremlin1234
posted on 5/1/17 at 09:15 PM |
another way to do it might be thread inserts / helicoils , but I don't think they are appropriate here.
Adamirish
posted on 5/1/17 at 10:02 PM |
It cod be trouble.
MK Indy 1700 Xflow
bi22le
posted on 5/1/17 at 11:19 PM |
Nuts in the other side would be fine if you can get there. You could lift your car from them 4 x M12 with bolts!
As long as the rust bit is bolted to hold ups. As previously mentioned.
posted on 6/1/17 at 11:51 AM |
Oooops! A typo there
posted on 6/1/17 at 01:09 PM |
Sorry for the slow reply guys, didn't see all these posts. I think you're right that it wasn't m10. Drilling it with a 10.5mm drill
didn't remove all traces of rust, which I think rules out m10. My googling showed that an m12x1.75 thread starts from 10.5mm hole. As an aside,
'what hole...' on google throws up some amazing predictions - sex education isn't what it used to be!
So it now has 5 m12 bolts done up tight (6th is obscured by the exhaust, I'll get my mate to do that at the next service), and it pulled a tonne
trailer fine.
Cheers for all the help.
posted on 6/1/17 at 01:11 PM |
Oh yeah, no access to get a nut behind.
