Author: Subject: FS. R6 Throttle body set up.
furryeggs
posted on 13/1/17 at 03:56 PM Reply With Quote
I have my R6 ITB set up for sale. These have been spaced with an ally fuel rail with fitting ready for AN fittings. The manifold plate was from DanST and runners TIG welded by me, not perfectly but should be more than ok. They are angled at roughly 30 degrees so are a little steeper than usual, I had alternator clearance issues, hence the steeper angle.
Inc trumpets, TPS and injector plugs with spare injectors (8 in total) and connector hoses.
There is a very slight bow on the plate from welding but with a thicker turbo gasket it pulls in when fitted to the head.
open to sensible offers...
[img][/img]
furryeggs
posted on 15/1/17 at 06:37 PM Reply With Quote
Can be split from manifold if its not required.
