New Topic New Reply
Author: Subject: Dark Times - Chassis Butchery
Ron Lang
posted on 15/1/17 at 01:05 PM Reply With Quote
So, as you all know, I purchased a near complete kit to finish and have so far discovered that the work has not been completed to a very high standard. I have ended up stripping the car right back to assess the damage and am rapidly realising this is a big job!
Yesterday, things got even worse. On taking the tunnel panels off (because they were poorly covered and poorly fixed) I found some worrying damage to the chassis sections. They appear to have taken an angle grinder to it, for apparently no reason, in multiple places along the tunnel. Clearly this needs fixing but can someone please tell me how bad this is. Will it be ok to weld the sections or does it need some plates welding in.
I'm so annoyed - I know taking on someone else's project is a risk but this is ridiculous.
Chassis Damage
Chassis Damage
Chassis Damage 2
Chassis Damage 2
Ron Lang
posted on 15/1/17 at 01:14 PM Reply With Quote
So I now have the front corners apart because the cycle wing brackets had been beaten with a hammer and calipers painted by a child. All GRP panels have been repainted poorly and are now cracking. I have also overhauled the whole indication side of the engine and ended up building a whole new engine harness to fix the homemade mess they had left. I have also started removing a lot of the bodywork as it's bent, poorly installed or scratched. And every piece of carpet has been installed with the wrong glue or a dirty surface and is coming away from the body. The scuttle has also been very poorly constructed and is falling to bits (and badly scratched)...
The list goes on.
StevieB
posted on 15/1/17 at 01:30 PM Reply With Quote
Bloody hell
Looks like they've welded something in then changed their minds after powder coating or something - just chop it out, don't need to make good afterwards!
I would have thought welding a piece back in to make the steel complete again should be enough. Might be easier to put a plate on though.
posted on 15/1/17 at 01:34 PM Reply With Quote
It might have been a good idea to inspect the car before parting with any money? Your car is a perfect example of why we should have an IVA system in place. Hope you get it sorted .
CosKev3
posted on 15/1/17 at 01:40 PM Reply With Quote
Oh dear.
That is bad
As above some small plates welded in will be fine.
This was probably IVA'ed with those holes there,as the tester wouldn't have removed the interior panels!
coyoteboy
posted on 15/1/17 at 02:03 PM Reply With Quote
Glad you had the diligence to inspect! Grab some angle of similer wall thickness and plate over, easy fix.
Ron Lang
posted on 15/1/17 at 02:08 PM Reply With Quote
Originally posted by CosKev3
Oh dear.
That is bad
The car wasn't IVA'd. It theoretically required finishing touches and some engine tuning but clearly not. I also agree that the IVA inspector wouldn't remove panels.
Ron Lang
posted on 15/1/17 at 02:12 PM Reply With Quote
I had to check as the idea was to sell this one on!!! I now feel I need to strip the whole car and check the whole chassis.
This was theoretically built by an ex-caterham mechanic!!!
CosKev3
posted on 15/1/17 at 02:15 PM Reply With Quote
A bad ex caterham mechanic by the looks!!!
Can't trust anyone selling a car from my experience
perksy
posted on 15/1/17 at 03:14 PM Reply With Quote
That's not good
I'd strip it right back. If they've left something as obviously bad as that, just think what they've tried to cover up
*If* it was an ex caterham mechanic I'll bet he didn't work there long...
ReMan
posted on 15/1/17 at 04:56 PM Reply With Quote
Yes obviously annoying , but not tragic! As mentioned plate or fillet weld it shut. Obviously an error or change of plan before., but agree it warrants careful checking of the rest, but fingers crossed this was done in haste and the rest is ok
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
mark chandler
posted on 15/1/17 at 07:13 PM Reply With Quote
It's not the end of the world, 1/2 hour with a welder will sort it.
From your initial post I was expecting twisted metal, this is just cutting out bracing as it was in the way.
Really needs plating and the strength put back by welding in braces a couple of inches further back.
Ron Lang
posted on 15/1/17 at 07:20 PM Reply With Quote
I can't work out what they were cutting out for though???
ReMan
posted on 15/1/17 at 07:26 PM Reply With Quote
Could have been a gearshift pivot if they were going bike engined?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
Ron Lang
posted on 15/1/17 at 07:43 PM Reply With Quote
That would make sense as it had bike tb's on it. I'll get in touch with a mobile welder this week and get it straightened out.
JacksAvon
posted on 15/1/17 at 10:03 PM Reply With Quote
Equally it could be a 'mechanic who once lived in Caterham
The sickness started in 2001 with a Robin Hood 3A, Prelit Westy,Tiger Cub, Tiger Avon, Tiger R6, 16v Mini, Sylva Fury Fireblade, Westfield Sei, Mallock Mk11, Fireblade Locost, Tiger Avon, Procomp LA Gold, Mk26 Mallock...........and now a Mk18 Mallock.....LR750, Vandiemen FX02
benchmark51
posted on 15/1/17 at 10:30 PM Reply With Quote
The welding needed in the pictures looks dead easy. I would cut small plates to fill the holes and mig them in. A bit of work with the angry grinder after would look better than covering the holes with larger plates. I would mig any unused drill holes too.
alfas
posted on 17/1/17 at 01:21 PM Reply With Quote
i would cover the holes (the ones near gearstick, the other near handbrake) with 1 piece of L-shaped steel, each side. liek a shoe over the existign chassis-rail.
closing the holes by small patches would not bring back the original stability to the chassis-tube
New Topic New Reply
