Author: Subject: What are these things called
bi22le
posted on 18/1/17 at 03:54 PM Reply With Quote
They may not be an off the shelf thing but. . .
Imagine an M6 threaded bar approx 50mm long about 10mm down is a nut that is formed onto the thread.
It means that you can use a spanner to put the bolt into a threaded hole and it provides you with a thread to put a nut on.
Any ideas?
Please read my ring story:
pekwah1
posted on 18/1/17 at 04:01 PM Reply With Quote
Sounds like a threaded rod with a nut welded on
But all joking aside, can you just do this, or a nyloc?
pekwah1
posted on 18/1/17 at 04:05 PM Reply With Quote
Could be: "adjuster rod"
hkp57
posted on 18/1/17 at 04:11 PM Reply With Quote
Not something I have come accross
Could you not just put in a piece of threaded rod and then lock it in with a nut?
Same end result, you can lock two nuts together onto the stud to screw it in then remove one but.
Fleet
SKC Raptor R - Hayabusa
Toyota C-HR Hybrid Limited Edition
Honda VFR1200 CrossTourer
DCT
Marlin Roadster 1800
Mercedes Vito 116 Sport
loggyboy
posted on 18/1/17 at 04:27 PM Reply With Quote
Double end screw/bolt/stud is closest term I can find that brings up some results.
[Edited on 18-1-17 by loggyboy]
peter030371
posted on 18/1/17 at 04:51 PM Reply With Quote
Bit like and exhaust stud but not seen one with a nut on.
sheepish0001
posted on 18/1/17 at 05:24 PM Reply With Quote
Sounds like a male turnbuckle this brings up lots of similar things that you describe
I've seem then used with female rods ends and such
HTH
bi22le
posted on 18/1/17 at 05:30 PM Reply With Quote
Thanks for the replies.
I think I have found the closest product. A male to male hex stand off.
In the end I am changing the design and going for these:
http://uk.rs-online.com/web/p/threaded-standoffs/8066663/?searchTerm=806-6663&relevancy-data=636F3D3126696E3D4931384E525353746F636B4E756D6265724D5 04E266C753D656E266D6D3D6D61746368616C6C26706D3D5E283F69292852537C5253207C52532D293F5C647B337D285C73293F5B5C732D2F255C2E2C5D285C73293F5C647B332C347D242 6706F3D313426736E3D592673743D52535F53544F434B5F4E554D4245522677633D4E4F4E45267573743D3830362D36363633267374613D3830363636363326
I need a cheap off the shelf product, I cant just make one in the garage. This is actually work related and I need 3000 of these a year!
indykid
posted on 18/1/17 at 06:33 PM Reply With Quote
Double ended stud or double ended hex flange stud. They appear to be specials, but 3k a year might not make them silly money if you're willing to hold a year's stock.
[Edited on 18/1/17 by indykid]
me? ambivalent? well, yes and no
jacko
posted on 18/1/17 at 07:20 PM Reply With Quote
https://www.brickwerks.co.uk/double-ended-stud-m6-x-22-14.html
something like this
jacko
Bluemoon
posted on 19/1/17 at 09:51 AM Reply With Quote
turnbuckle
http://www.swbmfg.com/titanium-turnbuckle/
[Edited on 19/1/17 by Bluemoon]
MattD
posted on 19/1/17 at 10:00 AM Reply With Quote
A PV stud ??
http://www.lmcurbs.com/catalog/p-PV-Stud.cfm
https://www.rapidmaterials.com/products/universal-pv-stud-replacement-for-s-5-pv-kits?variant=1330783873
[Edited on 19/1/17 by MattD]
