Author: Subject: Hayabusa parts wanted for supercharger project
deanspoors
posted on 20/1/17 at 02:03 PM Reply With Quote
Wanted as below for a gen 1.
Rotrex C30/94 supercharger, and or mounting bracket
Low compression pistons - 81mm
450/690cc injectors
adjustable cam sprockets, with/without cams
12mm head studs
Heavy duty output shaft
Steel rods
Bosch 044 fuel pump
uprated clutch basket
Blow off valve
Billet plenum
Cometic Head and Base Gasket
Wide band lambda sensor
Thanks,
Dean
