Author: Subject: Sierra steering alignment
super__dan
posted on 20/1/17 at 09:59 PM Reply With Quote
So the Indy I bought came with a small OMP steering wheel and quick release boss that I wanted to change. The steering boss has two sets of holes on slightly different PCD's, unfortunately the Momo wheel I've got fits the holes that are offset i.e. 30 degrees. No problem I thought, a couple of splines round on the steering boss but turns out the steering column is a hex, so is there an easy fix to this that's something I'm missing?
Many thanks,
Dan
Nickp
posted on 20/1/17 at 10:05 PM Reply With Quote
Re-align it on splined UJ further down the column I'd say, or re-track on rack.
Mash
posted on 20/1/17 at 10:14 PM Reply With Quote
Yup, as Nick said, you can re-align the spline down at the UJ (or mine does anyway)
Adamirish
posted on 21/1/17 at 06:08 PM Reply With Quote
It is splined at the rack. Just turn it there a couple of splines.
MK Indy 1700 Xflow
Smoking Frog
posted on 21/1/17 at 08:20 PM Reply With Quote
Once the steering wheel is fixed and the column is disconnected at the spline joint. Check that the rack is centralised by measuring the length of the track rod ends from the rack housing. When they measure the same the rack is centralised. Steering wheel in the straight ahead position and connect the column using the nearest spline. Any slight adjustment can be made at the track rod ends to ensure that the steering wheel remains at the straight ahead position.
super__dan
posted on 21/1/17 at 09:22 PM Reply With Quote
Thanks for all the advice. Had a look today, the track rods are equal (and painted over), it's just the rack that needs adjusting. Will change it at the rack splines next time I can and then I intend to have a geometry setup later in the year so will get it bob on then.
Cheers.
