Author: Subject: Zetec Water Rail wanted
wowblaauw
posted on 26/1/17 at 08:54 AM Reply With Quote
All,
This winters project was to re-wire my GBS Zero, replacing my home made wiring with a fit for purpose loom made by GBS. So far all is well. While I was doing this I decided there were other as important jobs to do; one of them is to do something about my home made water rail - I wanted the more professional version. Thus far, and having seen the offerings from Raceline, Burton and GBS et al, realised my already over stretched budget was not going to make it. Then I thought lets put a request out to see if any one had a water rail knocking around. If you have such a thing, then please do not hesitate to get in touch.
Thanks in advance
Craig
Myke 2463
posted on 26/1/17 at 01:39 PM Reply With Quote
Check out water rails on RWD Zetec World on FB. several different ideas.
Be Lucky Mike.
ragindave
posted on 27/1/17 at 11:06 AM Reply With Quote
Water rail.
I made this one up Ariel mast p clips etc
zetec cooling
zetec cooling
wowblaauw
posted on 27/1/17 at 05:59 PM Reply With Quote
That looks great. Is that using the stock Ford thermostat?
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, wine in the other, body thoroughly used up, totally worn out and screaming...
Damn, What a ride!!"
ragindave
posted on 27/1/17 at 06:18 PM Reply With Quote
Yes it is stock thermostat you can buy m6 stud and use stud connectors as spacers and 28mm aerial mast worked well and looks neat.
wowblaauw
posted on 27/1/17 at 06:21 PM Reply With Quote
It certainly does look neat and thank you for the ideas - actually I have most of the kit there, just hadn't thought about this way of routing. Thanks ragin D, much appreciated
wowblaauw
posted on 27/1/17 at 07:54 PM Reply With Quote
Just checked out the rwd zetec world Facebook and lo, water rails, options galore. A big thank you to Mike.
Be lucky
bi22le
posted on 27/1/17 at 08:40 PM Reply With Quote
I was going to mention RWD zetec on FB. I dont own a zetec but I love the cars that RWD zetecs end up in!!
Please read my ring story:
Ugg10
posted on 27/1/17 at 10:11 PM Reply With Quote
Not sure if this is what you are after (not sure if the link will work either), search Robert cheesmur on Facebook.
https://www.facebook.com/photo.php?fbid=10154331079108014&set=pcb.10154331080448014&type=3&theater
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
