Author: Subject: FS: Locost CBR919 Sprint-Hillclimb-RGB Race Car
ennten
posted on 30/1/17 at 03:54 PM Reply With Quote
I've decided to sell my 'Locost' Sprint and Hillclimb car before the start of the season to make way for my next single seater.
Currently the car is in Sprint/Hillcimb specification, running in class C12 of the 2016 AEMC Sprint championship. In 2015 it ran in class 4A (Sports Libre) of the NSCC Speed Championship. But it could be converted back to RGB spec.
If you are interested U2U me.
Price:
£8000 for car and 14 wheels and spare engines and trailer,
or
£7000 for car and wheels and spares, excluding the trailer.
I can get pictures of any specific parts though on request
Full specification:
MSA Logbooked, 2012 T89 Designs Locost Sprint Car. Eligible for Sports Libre (4A) or Modified Production (3F) if you revert back to 'Locost' silhouette or RGB with a few parts fitted (Handbrake and reverse)
Chassis:
Full round tube space frame.
FIA Homologated welded in roll cage made by Caged with side impact bar
Built to the size and silhouette of a Locost.
Satin Black enamel coated.
5215 Aluminium Front and Rear bulkheads
Front Running Gear:
Double wishbones, fully rose jointed with top Camber adjuster
Shocktec double adjustable shock absorbers
Playskool Motorsport Westfield wide track ARB
Rally Design Alloy uprights
Rally Design Alloy hubs
Steering:
Mk2 Escort 2.4 Turn Steering rack
M14 Rod End conerversion to remove heavy trackrod ends
Single Seater style fabricated steering column with AB Performance broached UJ's mounted in 3/4" rose joints
Sparco Steering wheel on Quick release boss
Brakes:
Wilwood Powerlite 4-pot front calipers
247mm Front Discs, Drilled and Grooved
Wilwood Dynapro 2 pot rear calipers
Lightened Drilled and grooved Sierra rear discs
Twin MC pedal with Bias bar and dash mounted adjuster
Full braided hose installation
Rear Running Gear:
Double wishbones, fully rose jointed with adjustable toe link
Lightened Sierra Bearing carriers
Modified MNR rear uprights with integral caliper mounts
Drivetrain:
Quaife ATB limited slip diff
Westfield 4.4:1 CWP in Freelander casing
2x long (RH) Westfield Megablade driveshafts
Westfield Hubs
Bailey Morris Propshaft (2 piece with Cush Tube)
AB Performance output flange
Engine/Fuel/Electronics/Controls:
Honda CBR 919 RRV Fireblade engine/gearbox, Dynojet Carbs, Billet Sump, uprated clutch springs, tuned exhasut manifold and Ram airbox.
Akrapovic Titanium Exhaust Can
Blackbird Reg/Rec
VW Polo radiator
9 Row Oil cooler with Mocal remote filter head.
Stick Shift with fully rose jointed linkage
ETB Digidash
Westfield Megablade Tacho
Custom made Mid Mounted 22 litre fuel tank
Kirkey Seat
TRS Harness (in date until end 2017)
Procomp Locost Pedal Set
RMD 25 Battery
Full light set (front headlights currently not fitted)
FIA Rain light
FIA electrical cut off
2.25LTR plumbed in fire extinguisher
Bodywork:
MK Indy Nose cone, scuttle and rear arches.
1050 Aluminium Panels
5251 Aluminium bonnet
Full Flat floor (easily removable)
Caterham wingstays with carbon/kevlar wings
Removable Carbon fibre rear diffuser (needs to be removed to get on and off the trailer)
Dallara Carbon Fibre front winglets
Wheels, 14 in total, 17 tyres in total.
4x 13" Compomotive MLs, 6" and 7", with Michelin S310 circuit slicks
4x 5.5 x 13 Cortina wheels with 185/60/13 R888's
2x 6.0 x 13 Escort RS wheels with 205/60/13 R888's
4x 13" Minilite-pattern sprint wheels, 7" and 8", with Avon sprint slicks. The front wheels are only 5 miles old.
3 x loose circuit slicks.
Spares:
Spare engine 1: Honda CBR 919 RRT: Complete engine including dynojetted carbs and air filter, wiring loom, fuel pump, prop output flange. Uprated clutch springs. I bought this as a complete engine and have never run it.
Spare engine 2: Honda CBR 919 RRV. Incomplete, some missing ancillaries. Full AB Performance 919 Fireblade pack. Gear selector problem.
Standard 3.21:1 Freelander Diff (better for long circuit work if you want to go racing)
Sprint and Race Brake pads
Various wheel spacers
TRS Passenger harness
All sorts of suspension and rose joint bits
Trailer :
1 Brian James Trailer, CM9-T044 Clubman 2100 HD, gross weight 2600kg, bed 4.00m x 1.85m, + safety pack, 2 gear winch braked, spare wheel mounted, wheel stop hocks, HD jockey wheel update, bought new in Sept 2010, approx 10,600 miles.
I am happy to sell the car without the trailer, but I won't sell the trailer until the car is sold.
Weight:
The car was last weighed at 440kg in sprint trim. A few pounds spent on a carbon fibre seat, a smaller fuel tank and a lightweight battery would bring the weight down to 420(ish)Kg which is very light for a fully caged car.
A bit of history:
I bought the car in October 2015 from LCB's own Doctor Derek Doctor.
In November 2015 I did 1 track day at Brands Hatch to learn the car, which ran faultlessly.
In March 2016 I did 1 sprint at Rockingham:
The morning's first practice session showed that I had chosen the wrong diff ratio. The sprint course used at Rockingham has a very fast first section, followed by a slower, twisty infield section.
The car quickly reached max revs in 6th gear and sat there for what felt like an age.
The afternoon's first timed run was worse. The car would not change up from 3rd gear. So I drove the entire track at 65mph.
The gear linkage was fine, pointing to a problem inside the gearbox. It was time to go home and take the engine/gearbox out.
Little did I know that the Locost would not leave the garage for the rest of the season.
Whilst waiting to repair the Locost gearbox, the opportunity arose to buy a Terrapin single-seater. I spent the 2016 season sprinting the Terrapin, and replaced the Locost engine over Christmas/New Year.
Older history:
DDD wrote: "I bought the chassis in 2010 from TimC, it had been collaberation with LCB'er Steve Hignett to be an RGB Race car. I was looking to start a build and had viewed nearly all of what was for sale from the usual suppliers (MK, MAC 1, Aries etc etc) and was about to make a purchase but when I saw this chassis I had to have it.
Its just a work of art, a full round tube spaceframe with an FIA homolgated Caged Roll Cage its probably most comparable to a Road Runner SR2. Its insanely light and really stiff, as a motorsport engineer its was just the best '7' chassis I had seen (sorry to gush)."
The chassis build thread is here:
http://www.locostbuilders.co.uk/viewthread.php?tid=132958
And finally, a few pictures:
ennten
posted on 8/2/17 at 08:02 AM Reply With Quote
Price reduced to 6,000 for car only (without trailer).
mash.
posted on 10/4/17 at 03:24 PM Reply With Quote
Still for sale?
ennten
posted on 10/4/17 at 03:40 PM Reply With Quote
Sold
LBMEFM
posted on 10/4/17 at 05:47 PM Reply With Quote
Not surprise it sold, what a brilliant bargain, someone's lucky?
