Author: Subject: Brake Cable (thwaites dumper)
gregs
posted on 5/2/17 at 05:19 PM Reply With Quote
Any ideas where I can get a replacement brake cable made up for my dumper? - ~800mm long with a clevis at each end (one being adjustable), not a bowden just a pull cable 1/4" diameter.
Cable/system stretched/bent beyond any effectiveness!
Greg
gary gsx
posted on 5/2/17 at 05:37 PM Reply With Quote
Hi mate
Very good place in Dorking Surrey called Venhills send your one as pattern obviously it needs to be shorter but they are very good and helpful.
Gary
gremlin1234
posted on 5/2/17 at 05:41 PM Reply With Quote
as an interim 'fix' you may be able to use a cable shortener / adjuster
http://www.oldclassiccar.co.uk/cable-adjusters.htm
mark chandler
posted on 5/2/17 at 06:11 PM Reply With Quote
My old dumper, benford just has rods!
I would look too boat yards, ships chandlers.
posted on 5/2/17 at 07:06 PM Reply With Quote
Speedy Cables are good but would probably need the old one as a pattern . Have you Goggled Benford parts?
BigFaceDave
posted on 5/2/17 at 09:26 PM Reply With Quote
Please tell me I'm not the only one that is slightly jealous as I don't have a dumper?
mark chandler
posted on 5/2/17 at 11:30 PM Reply With Quote
Mine looks like this, chugs away on a cup full of diesel all day.
https://goo.gl/images/z7qnCQ
Much better than a wheel barrow, it's a lovely old thing
robinj66
posted on 6/2/17 at 10:50 AM Reply With Quote
Have you had a look on ebay here
Alternatively you could try HTS or just a google search for "plant spares" to find someone more local to you.
ETA You might want to have a look at the caliper on the machine to find out why the cable got damaged. Often you will find that the adjustment has all been done on the handle end whereas there is also adjustment at the caliper (depending on the model). Sometimes the caliper adjuster is seized (open to the elements).
Might be worth downloading a diagram as there are a couple of systems used
[Edited on 6/2/17 by robinj66]
ReMan
posted on 6/2/17 at 01:23 PM Reply With Quote
Im searching Dumper on ebay right now!!
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
dinosaurjuice
posted on 6/2/17 at 02:26 PM Reply With Quote
This is too long: Handbrake Cable for Thwaites 5 & 6 Tonne Powershuttle Dumpers
but the seller might be able to help
ReMan
posted on 6/2/17 at 03:43 PM Reply With Quote
As its not a Bowden, could it be replace by a threaded rod and clivisses (clevii)?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
gregs
posted on 6/2/17 at 07:51 PM Reply With Quote
Thanks for all the pointers guys - I've found a wire rope place up the road so will give them a go to start with.
Greg
gregs
posted on 6/2/17 at 07:58 PM Reply With Quote
Had thought of it, but it run over the axle so prob not workable...
jacko
posted on 6/2/17 at 08:21 PM Reply With Quote
That you on the dumper
Jacko
